Half Pin, is this normal?- Mtbr.com
Results 1 to 5 of 5
    Reputation: flipnidaho's Avatar
    As part of the Rennen Rollenlager install, I also put in the provided half link to shorten my chain a little bit. However, the pin seem to be a little long. Is this normal? It doesn't seem to affect anything (chainring, cog or tensioner roller)... In the pic below, the pin showing is the same length that is showing on the other side...
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    Me thinks the plates are installed the wrong way, mainly from the pin sticking out and where the plate tapers down should be on the inside and the wide side pointing out.
    Like this instead...
    And He was Not
    Reputation: Enoch's Avatar
    Should be O.K.
    I dont have one with the cotter pin, But mine are a little longer than the regular chains. They shouldn't cause any problems regaurdless, assuming you are running them on a S/S.
    How do you like that tensioner?
    yep..... SS..
    I'm thinking it's a wider pin to allow for thicker chains...
    Reputation: Ken@Rennen's Avatar
    Jan 2005
    I just filed mine off... and I run a 9-speed chain.
    Bascially, I pryed apart the 1/2 link, and replaced the "donut" with one from a 9-speed chain, and then pressed it back together, making the link thinner.
    Just like you, the pin was too long, not that it would really matter for 1x1, but I am very particular.... so I filed it off nice and flush.
    RennenDesignGroup.com
    How 1x1 is DONE.
  1. OT/XP Removing/Replacing XT Hydro Levers?
    By Bikezilla in forum Downhill - Freeride
    Last Post: 11-26-2004, 12:20 AM
  2. Connex SS Chain + KMC half link = bliss
    By Objectionable Material in forum Singlespeed
    Last Post: 11-23-2004, 11:09 AM
  3. Makeshift wooden derailler pin
    By DakarRider in forum General Discussion
    Last Post: 08-10-2004, 02:16 PM
  4. Mono M4 pad pin removal
    By HollywoodUK in forum Brake Time
    Last Post: 07-19-2004, 02:03 AM
  5. Halfing, uh I mean half link...
    By indigosky in forum Singlespeed
    Last Post: 05-19-2004, 02:56 PM
