half link installation question- Mtbr.com
Results 1 to 6 of 6
    Reputation: wunderhorn's Avatar
    May 2005
    A quick question about installing a half link.
    My chain is not especially old but is getting saggy. I'm using the Soulcraft convert in push-up mode (with a zip tie), but I've run out of room to get tension because the roller is going to interfere w/ the chainstay. 34x17.
    So I'm thinking I will put a half link in there. By my calculations, I may even hit a magic gear; we shall see. My question is: With my existing SRAM 8-sp chain, am I correct that I could replace a link with a half link (yes, a narrow one), the old way, with a standard chain tool, simply by backing out two pins and installing the half link, again the old way with a chain tool? I'm asking because in the modern era I've only used Shimano 8sp chains, and I think I would not be able to do this w/o using Shimano's break-off pins and violating their "no adjacent break-off pins" rule/guidance. Thoughts much appreciated.
    Any thoughts on whether my chain will be too long to continue to run push-up mode would also be useful. . .
    Now with flavor!!
    Reputation: kidwoo's Avatar
    First, I would go to a shop and get them to check your stretch with a chain checker. You may actually be stretched out too much to be getting good engagement on your ring/cog if it's changed that much.
    I only have a dirtjump bike set up as a SS but I'm sure you lay down just as much power on an xc ride setup with a 2:1 gearing.........and for much longer periods. For that reason, I use a bmx chain. They stretch less and have good pin overlap that shifting chains lack.
    But if you need to keep your weight down, I'd still get a sram chain because you can do what you're describing without having to worry about the break-off shimano pin BS.
    Even with that I took a hammer and a punch and flared out the pins on my half link just in case. Maybe that's an option.
    I am currently using magic ratio
    Quote Originally Posted by wunderhorn
    If you can take up the slack in the chain and get the next pins to match vertically a half-link may work. If you are not close you will not be able to get the wheel back into the drop outs without a lot of tension. I can have the chain loose enough to hit my chainstay and still not get a 1 tooth bigger cog = 1/4 link to fit in. It takes a lot of slack for a half link to work. With the chain that loose only had it pop off once in a month.
    Also with a sram pc-68 chain i could not get an 8 sp Powerlink to close on a KMC 7/32" halflink. I had to buy a KMC 7.3mm Missing Link for the whole thing to work. Just using a standard pin on a sram chain with a kmc halflink maybe cutting it close.
    thump thump
    Reputation: artbeat's Avatar
    Dec 2005
    Quote Originally Posted by Ratt
    Why don't you take the guesswork out by using a gear calculator? Who knows - your chain might end up too short. Why ride a sagging chain anyways?
    http://www.peak.org/~fixin/personal/fmu/php/index.php
    "What is truth?" - Pilate to Jesus
    Rollin' a fatty Moderator
    Reputation: DiRt DeViL's Avatar
    Try a Spicer half link, used them successfully when was riding a converted frame.
    Search the forums for a thread about magic ratios, tons of options there.
    Quote Originally Posted by artbeat
    Well the whole thing started out tight as a drum with a new chain. On the park chain checker it stretched to about .45 and started hitting the chainstay. I put a 1 tooth bigger chainring to take up the slack but the rear wheel was a no-go or super tight in the drop outs. I think another .2 and it will fit.
