Gusset Single Speed Conversion- Mtbr.com
Results 1 to 13 of 13
    Dirt Burner
    Reputation: DirtDawg's Avatar
    Building my first SS MTB and Just wondering what your opinions are on the Gusset Single Speed Conversion. I'm considering the conversion instead of purchasing a new hub, just for my first SS build. So let me know if they are junk or ok.
    I believe there are people who disagree with my beliefs. I don't believe they are wrong. I know they are.
    - Ted Nugent
    So Much To Break, So Little Time
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by DirtDawg
    They're nice, clean and easy. If you don't feel like gathering up the stuff yourself, this is a good way to go. Just make sure that you don't have an aluminum freehub body or the skinny steel cog will gouge the splines.
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Reputation: Sweet_Corn's Avatar
    You will do just fine
    I ordered a similar conversion kit three years ago. It was awesome, and let me try singlespeed without a huge outlay of cash. The warning about the aluminum freehub body is accurate though, as I have done a little damage to the body of one of my hubs.
    Enjoy!
    My bike was -TWO- Wheels!
    Reputation: summitlt's Avatar
    I just used a bunch of spacers and the cog fo my choice. works great for me. And cheap!
    Schwinn Moab DS3 Avids, Rhyno Lites, Speed Dials, Some other stuff.
    Homebrew flat black rigid commuter with a Shockster
    Gary Fisher BMX
    Get Avid Juicy 7's for 65% off!!!
    Reputation: InfXXIV40-60's Avatar
    Gusset
    Had one...worked well.
    Enjoying Every Sandwich
    Reputation: TheBUNKY's Avatar
    They rock for us nooobies.......
    see?
    Nice and clean and you should be able to use most any other cog with it. Takes a lot of the headache out of your drivetrain portion of your build.
    The name's Norm...
    Reputation: maSSpayne's Avatar
    Runnin' one on my conversion...
    a '98 GT AgreSSor. With a Rollenlager.
    Reputation: mtbcyclist's Avatar
    I use one on my 96 Trek 7000 and love it. Chain alignment is perfect with stock cranks/bottom bracket. Nice and clean. Installs in a snap too. Highly recommend it. Got mine a www.pricepoint.com for something like $20.
    Submit to your ride!
    What is a good replacement cog for the stock Gusset cogs?
    Will the Boone Ti Cogs work with this kit?
    Quote Originally Posted by Sweet_Corn
    Enjoy!
    Reputation: the Inbred's Avatar
    the Novatec and/or Shimano DX cogs.
    i got a Gusset and wasn't a big fan. i like the adjustability from using spacers.
    Dirt Burner
    Thanks for the feedback - I think I will have to give the gusset SS conversion and the whole SingleSpeed thing a try.
    - Ted Nugent
    i worship Mr T
    Reputation: *rt*'s Avatar
    i like mine
    using it on a Surly with an LX hub. has worked great so far. before i got it i also asked and a lot of people suggested using spacers for easier adjustment of the chainline. i didn't have that many spacers lying around and in the end i had absolutely no problem getting the chainline set up with the Gusset. i put it on & voila! ready to roll.
    rt
    "where are you not going so fast?" (question asked to cyclist on a trainer)
    *rt*'s fabulous blog
    mm blogging
    Ebo
    Ebo is offline
    Same. Got the DX cog and an aluminum spacer kit at Excel Sports for $15. Although I'm sure the Gusset works ok, you can really fine tune the chain line with the spacers. 2cents.
  1. 1st single speed conversion, s. moab-3
    By TrailNut in forum Singlespeed
    Last Post: 01-07-2005, 10:46 AM
  2. Faster on a single speed?
    By Greenfix in forum Singlespeed
    Last Post: 11-18-2004, 12:14 PM
  3. Replies: 16
    Last Post: 07-05-2004, 01:34 AM
  4. New softtail single speed, Trek STP.........
    By KMan in forum Singlespeed
    Last Post: 07-02-2004, 06:42 AM
  5. Using factory made wheels on a single speed
    By Dimitri Nikas in forum Singlespeed
    Last Post: 01-31-2004, 03:23 PM
