Grocery Getter.....- Mtbr.com
Results 1 to 9 of 9
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Grocery Getter.....
    .....with an ulterior motive. I'll get her hooked on the short jaunt to the store and hopefully it won't be long before she's regularly using the hard stuff.
    Also, the streets are full of horizontal dropouts...
    BSNYC
    Nice utility bike.
    Hey does anybody know where to get the old fasioned wire baskets for the rear of a bike?
    Reputation: Strike the primer's Avatar
    That is the nicest C-Dale I have ever seen.
    Out spokin'
    Dec 1999
    If that doesn't do it, nothing will. Sweet lookin' ride. How are you tensioning the chain on that bad girl?
    --Sparty
    disciplesofdirt.org
    --Sparty
    It's "adequate" right now, at least for the purpose of making sure that the current gearing is going to be OK. If that proves to be the case I'll just replace the worn chain that's on there now with a new one & that should do the trick. As much as I'd like to pretend otherwise, this bike will be lucky to see 100 miles a year so that should be a relatively good solution. Based on what I've got right now if I have to lower the gearing I'll just go two teeth bigger on the cog and add a half-link.
    I'm glad that this bike ended up having "magic" chainstays. I used to own a Convert, but it disappeared when some scabby tweaker pinched my grocery getter, an '83 Stumpy that I had converted to SS. He also got the first set of wheels I ever built in the bargain, some absolutely bombproof Ambrosio Durex rims laced 14g 3x to the original Specialized hubs. No, I'm not over it yet.......
    BSNYC
    meh... whatever
    Reputation: monogod's Avatar
    Feb 2006
    Quote Originally Posted by Traktor
    lbs.
    whats not in stock can be ordered.
    "Knowledge is good." ~ Emil Faber
    Out spokin'
    Dec 1999
    Quote Originally Posted by quaffimodo
    ...an '83 Stumpy ... No, I'm not over it yet.......
    '83 Stumpjumper?!?! Can you say, "collector's item"?
    I've got an '84 Diamond Back Mean Streak in my storage container... my first mtn bike... ain't lettin' nobody git at 'er.
    --Sparty
    disciplesofdirt.org
    --Sparty
    Can you cay "50 worth of scrap metal?" I hates me some tweakers, I do.
    BSNYC
