Got Drill ??- Mtbr.com
Results 1 to 6 of 6
Thread: Got Drill ??
    Cracker-magnon
    Reputation: gpsser's Avatar
    Got Drill ??
    And some time to kill. Had a little fun this evening installing some Rivnuts on the underside of the downtube to add a third bottle cage.
    Pic #1: The parts
    Pic #2:Oh No!, Mr. Bill!
    Pic #3:New bottle bosses
    Pic #4:With Cage
    Pic #5:Ready to Roll
    "Life is a F@#^ing story problem, get used to it - my son.
    singlespeed smash brother
    Reputation: shwinboy's Avatar
    How do you stop the inserts from just pulling out again?
    Cracker-magnon
    Quote Originally Posted by shwinboy
    Rivnuts are essentially just threaded rivets. The upper part compresses vertically and expands laterally inside the tube. You can buy a gun to set them for $20+, or use a longish bolt in combination with a nut and some washers to do it for less than a buck.
    Medium?
    Reputation: Fast Eddy's Avatar
    Please explain Mr. Rivnut
    How do you get the nut that you use to compress the rivnut into and out of the tube? My old fixie needs a cage. Where do you get them?
    Nut Inserts
    check here:
    http://www.mcmaster.com/
    page 3069
    Cracker-magnon
    Quote Originally Posted by Fast Eddy
    Bike Tools Etc. (Thanks to Aosty who did this to his Dean)
    search for rivnuts, they also have drill bits, etc. both alum and steel nuts.
    the bolt that I used to compress them is just a longer version of a bottle cage bolt. it just uses the threads. spin it in with a nut on it, and then hold it still while you back the nut down onto the frame, compressing the rivnut. Took 1/2 hour tops. you can google rivnuts (or rivnut tool, etc.) for lots of install tips and home made tools as well.
  1. Best way to widen valve hole for Stan's rimstrip?
    By IFrider1 in forum Wheels and Tires
    Last Post: 02-02-2004, 11:53 AM
  2. I did something without asking THE forum first
    By Juanjo in forum Downhill - Freeride
    Last Post: 01-29-2004, 05:35 PM
  3. Crank bolt stripped, help!
    By MBA in forum Singlespeed
    Last Post: 01-26-2004, 10:13 PM
  4. Shortening ti bolts
    By baker in forum Weight Weenies
    Last Post: 01-23-2004, 05:34 PM
  5. Drilling out solid axle off-center?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 01-14-2004, 12:26 PM
