Good tires for my SS?- Mtbr.com
Results 1 to 22 of 22
    Looking for a new set of tires for my RIGID SS? What do you' all ride?
    Quote Originally Posted by GRUMP
    I ride Michelin comp S's. They work in nearly any condition.
    Reputation: noslogan's Avatar
    this season
    I like the Kenda Blue Groove 2.3 in the front and Nevegal in the rear.
    Reviewer/Tester
    Reputation: Rainman's Avatar
    WTB Nano's or Exiwolfs.
    R.
    It is inevitable ...
    Reputation: shiggy's Avatar
    Dec 1998
    I use everything from the Conti Crosscountry 1.5 to the Nokian Gazzaloddi 3.0.
    mtbtires.com
    TRAIL KUBUKI CORNDOGGER
    Reputation: TwistedCrank's Avatar
    rubber ones with throbbing knobs
    Nobody cares what kind of bike you ride.
    FIFI!
    Reputation: Weaver's Avatar
    Feb 2005
    i just use those panaracer fire xc pros.
    i'm not to picky on tires though, so long as i can roll forward i'm happy.
    these got good reviews and they looked pretty so i bought em'.
    i like my tires on the skinnier side too.
    Reputation: montclairbobbyb's Avatar
    Aug 2003
    Tires for my SS
    Dear Mr. GRUMP:
    I run a 2.3 Klein Death Grip on the back and a 2.3 Continental Vertical on the front. The bike is a Zion 843 EBB (steel) with Surly rigid fork, so I want as much rubber as possible... Oh, and did I mention, I chose these because they were given to me for free?.....
    But I do prefer wide tires... good luck
    Reputation: AK47's Avatar
    I recently tried WTB Weirwolfs on my G.U.S.S. and love 'em! Check out www.universalcycles.com for a killer deal right now on the kevlar version.
    Drinker w/ Riding Problem
    Reputation: brado1's Avatar
    Continental Vertical in the rear and a Michelin Wildgripper XLS in the front, used to run Hot S in the rear but had issues with weak sidewalls tearing on jagged rocks, Conti's have been good and taken the abuse.
    What kind of trails do you ride?
    Pisgah
    Quote Originally Posted by dumbaSS
    Pisgah, rocky, rooty, wet knarliness, the good stuff. I ride the same trails i used to ride my Id on.
    note top photo not of me, nor did i take it - Pilot Rock rocks. Good stuff! this is the trails i ride. the others are mine however not as spectacular as Broussard's
    Quote Originally Posted by brado1
    Looks just like the trails here in PA. I'm no singlespeed expert, new to it this season, but I hate to see any discussion of tires without trail info.
    For what it's worth I recently switched to 2.4 Mutanoraptors after seeing lots of people here digging them. I have to say it's a big improvement over the Python 2.3's I was using. I think you're going to want something high volume for rocks/roots like that.
    The trails I ride consist of hardpack, loose and rocky. Nothing I ride is rooty or wet(not yet anyway). I live in SoCal.
    Gaa-zee-raaaa!
    Reputation: Godzilla's Avatar
    Mar 2005
    I was running High Roller semi slick 2.35 f&r before my last bike was stolen - I liked them alot, they rolled really fast, had DH casings, were ghetto tubeless worthy (this is how I was running them) and had enough shoulder to give me confidence in the corners, slow and fast. They also had more than enough traction for climbing, suprisingly.
    I am not able to run them now, because my new setup is 24"/26" and they are not available in 24" - but would go back to the setup without hesitation if it were an option. The trails I ride vary from loose / rocky to hardpack, few roots - but lots of very sharp rocks. I ride mostly Front Range, CO (Denver)
    Now with more vitriol!
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    Whatever's fat and cheap!
    I run the 2.35 Kenda kinetics cuz they were cheap and they are about all I can squeeze into the rear end of my Zion 853 EBB! I could go way bigger on the front (surly fork) but I have been happy with the performance so far.
    J_T
    J_T is offline
    Pale-ale-ontologist
    Reputation: J_T's Avatar
    Dec 2004
    Wtb
    Motoraptor 2.24 race ( I get them at cost)
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    thanks no cog frog! three cheers for cheap arse tyres that work. i have spent a small fortune on experiments and nothing has been able to knock the olde kenda kinetics (wire bead no less) from the top of the pile.
    sure they are a bear to change when mounted on big rims like rhyno lites but they have been flat proof for 2 years now...
    Expert of the Internet.
    BECAUSE I SAID SO
    Reputation: marsb's Avatar
    Quote Originally Posted by AK47
    I'm digging the Weirwolfs myself. I am running a 2.5 light layup front and a 2.5 fR version on the rear, and have been very pleased in everything except real muddy conditions (when you shouldn't be riding anyway )
    don't try this at home
    Reputation: moschika's Avatar
    i really like the a reversed mutano 2.4 in back and a 2.5 weir in front. best combo. nothing like big fat tires, especially if riding rigid. i ride bumpy, twisty singletrack.
    will you rep me?
    Reputation: pitmang1's Avatar
    Front Kenda Nevegal 2.35
    Back Maxxis Hansventure 2.35
    I have right now a Larsen TT on the back and it just slips around in the loose stuff when you try to pedal standing. Might be good for someone with a granny gear, but I only have one gear and it's not for old ladies.
    The devil is an angel too
    Mar 2005
    Quote Originally Posted by nogearshere
    I have been less than impressed with their performance on muddy/wet trails. And mine (non-stickE) seemed to be downright scary on wet roots.
    On hard pack and/or loose drier soil they work pretty good though.
