Gearing - 3 days of long flat roads and monster climbs- Mtbr.com
Results 1 to 8 of 8
    I need some help with choosing a ratio for an upcoming epic ride 3 day ride with my geared mates. Each day is about 100km. The route consists of lots of long flat or rolling roads with at least one monster climb a day. The first day has two monster climbs and the next two days each have the toughest hill I have had to face yet - approx 14km at 1:7 grade.
    I currently run a 36:21 ratio on my (steep) local trails which is fine for all but the meanest climb. For this climb a 36:23 still has me pushing some pitches but is very slow on the flats.
    For the epic ride, is it better in your experience to run a flatland ratio like 36:15 and resign myself to push up the climbs, or should I do the reverse and run the 36:23 and be slower on the flats but stand a chance of making it on the hills ?
    All advice and anecdotes appreciated.
    ____________
    Fear only Fear
    I'm feeling dirty, you?
    Reputation: jonowee's Avatar
    What kind of frame or hub is the bike you're intending of using for this very neat sounding trip?
    EBB/Track ends/Sliding dropouts/ENO/Flip-flop hub/single-sided hub?
    Quote Originally Posted by OneFear
    What rear hub do you have? I think it is possible to fix an extra freewheel onto the non-drive side of certain hubs, then when the going gets tough you just get off the bike and turn the wheel around to the easier ratio.
    It sounds like a good solution for the ride you describe, so maybe worth looking into.
    Hub info
    Sorry, I should have given more info on the bike.
    Its an Inbred with Horizontal drops and I run a Shimano cassette hub with a single sprocket and spacers converted to bolt-on.
    As a pride thing I probably wouldn't want to change gears. In past enduro-type events I have run easier gearing and spun a lot which seemed to work ok. This trip is both flatter and with meaner hills than before so I am a bit confused...
    ____________
    Fear only Fear
    In that case if I were in your shoes, I would ehhh... do a 36:18 gear ratio which is simply 2:1 gearing, 3 teeth more in the rear for the flats than the 15T and 3 teeth less than the 21T climbing gear.
    I know I just simplify it into a very non-scientific answer almost trivalised the concept of the 'best' ratio, but hey less spinning on the flats, climable and just deal with maybe having to hike-a-bike if needed on the nastiest climbs.
    Those tough hills you mentioned sound sickening to me if I were caught out on a 36:15, Have a Good One OneFear.
    Maybe I have done my math
    incorrectly, which is highly possible, but It looks like to me you are climbing 6500' plus or minus. I think that is a lot of feet in 8.6 miles and I just don't think any gear is going to work out for you. Kent Peterson rides almost always on a fixed gear and rides everywhere. You might check out his site for ideas of gearing. Good luck, I don't envy you at all. Just wondering where is this ride to take place? Sounds tough and maybe needs a little write up.
    http://www.mile43.com/peterson/rando.html
    Good luck, Ed
    Reputation: the Inbred's Avatar
    well, spinning too much on flats is gonna tire you out, as well. i say go somewhere in the middle.
    Reputation: WadePatton's Avatar
    May 1999
    Not the answer you're looking for, but it sounds good to me.
    Get a flip/flop rear wheel and run FIXED in the flats and Freewheel uphill. So- big gear fixed and little gear freewheeled.
    Not singlespeed--but not quite indexed either.
    I would rather have a bottle in front of me than a frontal lobotomy. W.C. Fields
