Geared to SS conversion- Mtbr.com
Results 1 to 17 of 17
    Reputation: j69nx's Avatar
    Smile Geared to SS conversion
    Singlespeed gurus,
    2010 Bontrager RXL 29er rear wheel geared. What do I need, really? I have mixed suggestions from LBS and riders about conversion sets.
    Frame=2012 Niner One 9 ordered and XTR 970 32t front.
    Any pictures(bling) will be well appreciated.
    Thanks,
    Al
    Spacers and a cog.
    MTBR.com Single Speed Forum - Single Speed FAQ
    There is a FAQ sticky.
    Reputation: PoisonDartFrog's Avatar
    Quote Originally Posted by j69nx View Post
    What have you been told?
    Price Point - Search Results for single speed
    Conversion kit and chain tensioner.
    Mind your own religion.
    Quote Originally Posted by PoisonDartFrog View Post
    He's ordered a One 9. No tensioner necessary. And that conversion kit comes with garbage stamped cogs, which I wouldn't recommend.
    You need this tensioner, sure its a little pricy but its by far the best I've seen!
    Soulcraft - Top Notch Bicycle Frames - Petaluma, CA - Mountain, Road, Cyclocross, Singlespeed, 29er
    Quote Originally Posted by ridefast84 View Post
    Do you people even read the entire post before you start typing?
    Reputation: luvdabeach2001's Avatar
    1-1/4" PVC pipe, to make spacers, and a cassette to cannibalize until you find the right gearing i.e. 32x18, 32x16. You can also use some of the spacers in the cassette to adjust alignment.
    Quote Originally Posted by phsycle View Post
    Relax, my bad bro! Some people's children these days! Didn't realize the one 9 had ebb.
    surly inbred
    Reputation: TroutBum's Avatar
    You need to stretch... this is gonna hurt a bit.
    Very informative...
    PoisonDartFrog---singleator and chain guides. I just want to be sure that Niner frame and its ebb 2 is all I need so I don't have to deal with chainlines when switching the geared hub to SS. Any thoughts?
    I'm ready for the beating with the carbon fork. They say I have to loosen up on bumps and downhills.
    nothing to see here
    Reputation: Stevob's Avatar
    They are right. You'll have a fairly steep learning curve. The plus side is that it will climb that much better and that'll mean you'll persist with the downhill technique until you get it right. Get a big cushy front tyre.
    FWIW, the Niner is single speed ready. Follow the instructions for the EBB. You'll need nothing else to add that will affect your chainline. Just measure the chainline properly. Half the width of the seat tube, add that to the distance from seat tube to chainring. That's your chainline to work with. Take that figure and subtract it from 67.5. Take the result and (with the rear wheel off) measure from where the inside of the dropout contacts the axle. Use a ruler or other straight object placed flush against the axle face to assist in getting the measurement accurate with the height of the rear sprocket.
    I see hills.
    I want to climb them.
    Thanks for the advice. This forum always helps me when I do builds or any technical questions. I cant wait now.
    Update: Niner air 9 carbon and Gearclamp conversion kit. No spacers needed. I'm not sure if a non tapered Niner fork will look seamless.
    Here she comes. Awaiting the RDO seatpost and will complete the build
    Hi, i need some help - i am doing a SS project and have a Rotor 3D crankset on my bike - i want to know what 32T chainring would fit and work on that crankset - it is 5bolt and BCD is 110/74 - not sure what that means..... i am in South Africa and have limited recourses to components... please assist?
