Gear Set Up- Mtbr.com
Results 1 to 21 of 21
Thread: Gear Set Up
    Jul 2016
    Gear Set Up
    Just looking for a overall gear set up. Currently I'm running 29t/20t and I find that setup a little light for me. My trails are fairly simple. Does anyone have any suggestions? Where is a good place to get it from? Thanks
    Downcountry AF
    Oct 2013
    32:18, lbs
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: coke's Avatar
    Try an 18t. If it's still too easy, consider a 17t cog or possibly a 32t chainring. If the 18t is too hard, get a 19t.
    I think it's good to have a few different cogs if you have a variety of trails. I don't change mine much for general riding, but for racing I'll run a 32t oval up front and either 17, 18, 19, or 20 depending on which race it is.
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    Generally speaking you start off with a 2:1 (i.e. 32:16) and then vary it from there depending upon your trails. I tend to climb alot and still run 32:17 this time in the season. Early in the Spring, I sometimes will switch to a 32:18
    "And crawling on the planet's face, some insects called, The Human Race..."
    According to others online, you would be better served getting a larger front ring first. Apparently, if you take two identical ratio's, one with two larger rings and one with two smaller, the larger will be more efficient. Based on that, I would go... say 32 front, see how it feels, then buy a rear if necessary.
    I run a 32x21 or 32x22 on my 29er's to deal with the steeps in Boise. From another thread, many seem very happy at 32x20.
    Jan 2009
    I feel like the 2:1 rule works for 26ers, but you need a little more gear for a 29er, if that's what you are after. 32/20 works well for the short hills in central texas. If I lived somewhere flatter, I would go 32/18.
    Quote Originally Posted by mack_turtle View Post
    Good point! I'm still on a 26"
    Jul 2016
    Thanks for all the input. Going with 32:18 just hope I will be able to hang with that set up. Had to drop bike off bike at the shop because the crank seized up on me. It was difficult to turn.
    Feb 2016
    Quote Originally Posted by Jeepfan View Post
    Assuming that the bike has 29" wheels and a 170 mm crank:
    29/20- 42 gear inches ( 10 mph @80 rpm)
    32/18- 51.4 gear inches (12.2 mph @80 rpm)
    So that's quite a bit of a jump, but for simple trails( no crazy extended climbs) that should work great. If it's too much, throw the 20t cog back on. That will put you at:
    32/20- 46 gear inches ( 11 mph @80 rpm)
    For reference:
    Gear calculator-
    Sheldon Brown's Bicycle Gear Calculator
    Gear Theory explained-
    Gear Theory for Bicyclists
    Jul 2016
    Quote Originally Posted by brunjc2 View Post
    For reference:
    Gear calculator-
    Thanks for the links. I didn't consider the jump in gears hopefully I'll be able to handle it. But like you said I'll hold onto the 20t for now. My current setup of 29/20 is just too light for me. You are absolutely correct I am running 29" wheels I am not sure of the crank.
    Feb 2016
    I think you'll find it close to perfect.
    EXORCIZE
    Reputation: Ryder1's Avatar
    29/20 to 32/18 is BIG change. I find the first too easy (tedious) and the latter too hard for most trails. 32/20 is a great place to start, then move to 32/19 when you get the itch.
    EXORCIZE
    Quote Originally Posted by garcia View Post
    Seriously?
    Feb 2016
    I ride a 32/16 (29er 175mm crank) and its just right. Before that ran a 34/18. Depends on where you ride, what your target cadence is, etc etc.
    Reputation: Flat Ark's Avatar
    Quote Originally Posted by Ryder1 View Post
    Seriously?
    Gerry Pflug claims this to be the case.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    EXORCIZE
    After realizing I initially misread your post, then doing some "research" - it appears there's some truth in this, that big/big is slightly more efficient (less drivetrain loss) than small/small. Most SSers run a 32t ring, give or take, so probably not worth sweating over. But yeah, everything else being equal, 32/20 may be a hair more efficient than 29/18.
    Jul 2016
    Ok I tried the 32/18 and it is a lot better than I had before. I'm glad the places I ride are fairly flat going to go with the 32/18 setup for a couple of weeks then try the 32/20
    Jul 2016
    I going to have to try the 32/19 then
    Aug 2010
    Lots of climbing here so mtb I run 36x22 or 32x20. If I take her out on gravel roads I will run 36x18 usually.
    Reputation: Crankyone's Avatar
    Dec 2014
    32x18 -26" for me. still gives me a lot of cardio on the climbs!
    Feb 2005
    Bigger gears mean less bend for the chain. Some say it's a better set up. My current is a 34x22 for my steep local trails.
    [COLOR="Black"]HARDMTNBIKER on Instagram
    Seven Sola SLX ENVE MTN SS
    Sir9 Carbon Niner SS
    #1gearallyear #Iridemtn
    Feb 2016
    Quote Originally Posted by khardrunner14 View Post
    What area are you located in? I'm in FL so I have no right to complain about climbs. There are climbs, but they're all very manageable. I just ran a 32x16 on my 29er this week and I think that's the sweet spot for me.
  1. Shimano SLX Rear Derailleur Adjustment - Skips Gear & Moves Back To Correct Gear
    By BobaX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2016, 07:36 AM
  2. Replies: 9
    Last Post: 08-04-2015, 06:19 AM
  3. Rear Shifter changes gear, but does not change display gear.
    By ERMAHGERD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-12-2015, 12:15 AM
  4. rear gear changing problems, xt/xtr gear
    By LoZzA199 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2014, 03:06 PM
