Are gear ratios created equal...- Mtbr.com
Results 1 to 8 of 8
    dmo
    dmo is offline
    Reputation: dmo's Avatar
    Does it matter if you use a 30t or 32t chainring but still get the same ratio by using different sized cogs? Is there any reason using a 32t would be better than a 30t.
    Sent from my SM-G955U using Tapatalk
    Reputation: JoePAz's Avatar
    May 2012
    Things like gear wrap and one some frames certain ratios are harder to tension the chain.
    I run a 34 chainring on my single speed mostly with 19t, but I also have 20t and 18t. I have sliders so all 3 cogs work with same chain just by adjusting the sliders. I should be able to also get a 21t if wanted and maybe a 17t.
    Joe
    '18 Specialized Epic 29", Vassago Verhauen SS 29", '13 Santa Cruz Solo 27.5", XC, AM, blah blah blah.. I just ride.
    Reputation: DualRollers's Avatar
    Apr 2014
    Efficiency wise it won't make a difference. As mentioned above, things like chain wrap, clearance, wheel position in the dropouts, etc all matter to most people though.
    dmo
    dmo is offline
    Quote Originally Posted by DualRollers View Post
    So what's better a 32t or 30t ring? Or does it depend on the frame?
    Apr 2014
    It really depends on your frame. Personally I run a 30t because my frame has a lower bottom bracket, and we have a lot of big rock stepups that I like to have all the extra clearance I can get under the bike. With that said, I don't like the position my wheel is in with 30/18. It's give or take and you really just have to experiment. I used to run 25/15 on the same bike but was going through chains a lot quicker than a bigger gear setup, so I switched.
    Cogs are cheap, I would say just experiment and find what you like.
    more skier than biker
    Nov 2006
    Running larger cogs and chainrings versus their comparable smaller sizes for the same ratio (i.e. 36x18 vs a 32x16), will result in less wear of the drivetrain since the loads are spread out more
    Armature speller
    Sep 2004
    Apart from rock strikes, there's no downside to bigger rings/cogs apart from weight.
    As long as your frame can handle it.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Assuming BB height is not an issue and the relative position of chain stay sliders are good (in terms of tire clearance), I prefer running a somewhat larger ring (typically 36t with 17 - 19t cogs).
    【ツ】 eDub 【ツ】
  1. Are all G2's created equal?
    By mech1 in forum 29er Bikes
    Last Post: 07-24-2011, 06:29 AM
  2. Bearing created equal??
    By 2fast4u in forum Weight Weenies
    Last Post: 07-09-2011, 10:02 PM
  3. Are all bearings created equal?
    By MattZo in forum Intense
    Last Post: 05-23-2011, 01:05 PM
  4. are all ARC's created equal?
    By iwantalitebike in forum Yeti
    Last Post: 05-15-2011, 03:34 AM
  5. are all brake pads created equal? (for avid juicy 5)
    By ride the biscuit in forum All Mountain
    Last Post: 02-15-2011, 11:11 AM
