Gear Ratio to wheel travel- Mtbr.com
Results 1 to 6 of 6
    www.justthebonnet.com
    Reputation: Capt_phun's Avatar
    Ok maybe I'm dumb (probably) but if I run 32:16 and 34:17 it is still a 2:1 gear ratio. But this is my question is the travel of the bike, ie. distance on the ground I move in one pedal revolution the same? I know this is a newbie question, but hey I'm burnt so work withme here. Cause if it isn't then it would reason to make sense to run 34:17 versus 32:16 or is it easier on 32:16.
    Ok simplify the question, why would one run 34:17 versus 32:16?
    thanks
    the capt.
    hand me the dice
    Reputation: TryAndStopMe's Avatar
    Quote Originally Posted by Capt_phun
    thanks
    the capt.
    the gear inch, ratio and travel is the same for those 2 configurations. the only reason for running the 34:17 would be that it wouldn't wear as fast as the 32:16.
    there's a nifty java gear calculator at chainrings.com
    "pain is only a pulse...if you just stop feeling it"
    Out spokin'
    Dec 1999
    Same-o, same-o
    Ok simplify the question, why would one run 34:17 versus 32:16? thanks the capt.
    The gear ratio is the same, therefore the distance traveled will be the same.
    One good reason to use a larger ring and larger cog is that the larger equipment will wear ever so slightly slower. Chains, cogs and rings are expensive. Alternately, the larger equipment weights ever so slightly more.
    --Sparty
    disciplesofdirt.org
    Reputation: Gearless Dave's Avatar
    Not al 2:1 are the same
    --Sparty
    It's a bugger of a math problem, but low and behold there are mechnical advantages to running a larger 2:1 than a smaller one (i.e 40:20 vs. 32:16). It has to do with the distance of the drive and lever arm from the point of rotation (BB spindle). Ask any mechanical engineering prof and he could probably explain it better than I. In practice the improved output (watts) from the same input (pedal stroke power) using a larger 2:1 is probably negated by the increased weight of the larger rings and longer chain. Dave
    highly visible
    Reputation: GlowBoy's Avatar
    Quote Originally Posted by Gearless Dave
    2:1 is 2:1. The only "mechanical advantage" of the larger 2:1 is that it is slightly more efficient (and some can even tell the difference in terms of smoother pedaling). You will require very slightly less effort to go a given distance, but it will still take the same number of crank revolutions to achieve that distance.
    - Dan
    Out spokin'
    Dec 1999
    <TABLE cellSpacing=0 cellPadding=6 width="100%" border=0><TBODY><TR><TD class=alt1 style="BORDER-RIGHT: 1px inset; BORDER-TOP: 1px inset; BORDER-LEFT: 1px inset; BORDER-BOTTOM: 1px inset">Originally Posted by Gearless Dave
    It's a bugger of a math problem, but low and behold there are mechnical advantages to running a larger 2:1 than a smaller one (i.e 40:20 vs. 32:16). It has to do with the distance of the drive and lever arm from the point of rotation (BB spindle). Ask any mechanical engineering prof and he could probably explain it better than I. In practice the improved output (watts) from the same input (pedal stroke power) using a larger 2:1 is probably negated by the increased weight of the larger rings and longer chain. Dave </TD></TR></TBODY></TABLE>
    Quote Originally Posted by GlowBoy
    - Dan
    I wonder if you guys are saying the same thing.
    --Sparty
    disciplesofdirt.org
  1. New 24/3.0's!
    By Darknut in forum Downhill - Freeride
    Last Post: 02-23-2004, 11:17 AM
  2. How much travel does your fork really get?
    By Structure in forum Shocks and Suspension
    Last Post: 02-14-2004, 07:02 PM
  3. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
  4. HTML/VbCode test thread: View at your own risk!
    By FireDog46 in forum Eastern Canada
    Last Post: 02-03-2004, 10:27 AM
  5. Replies: 4
    Last Post: 01-22-2004, 12:09 PM
