Gear ratio question- Mtbr.com
Results 1 to 16 of 16
    offroader
    Dec 2008
    Gear ratio question
    What's the difference between running 32x18, 34x20, or 22x13 ratios?
    I'm currently running a 34x20 which is probably equivalent to a 32x19. If 22x13 is the same ratio wouldn't it be better to run the smaller cog/chainring to save weight? What other factors are there in choosing a gear ratio?
    Mtbr Forum Sponsor - Homebrewed Components
    faster wear is probably the biggest thing. If your cog is half the size, it'll probably wear out twice as fast. Same with the chainring.
    but they are all a little different from each other as far as ratio goes.
    32-18: 1:1.777777
    34-20: 1:1.7
    22-13: 1:1.6923
    but i know what you mean....
    Over the bars...
    Reputation: egggman's Avatar
    Also I believe a smoother spin with more points of engagement. But if we are Single do we really want to be engaged. Now there is the real question... Cheeze!!
    offroader
    Dec 2008
    Quote Originally Posted by egggman
    Smoother spin with the bigger gears? What do you mean by points of engagement. Thanks
    Over the bars...
    I may be off on what points of engagement mean but in this case I believe it is how many teeth contact the chain at any given point. I also did a little Sheldon Brown reading and he has some good info on reasons for big or small cogs and chainrings.
    http://www.sheldonbrown.com/singlespeed.html
    offroader
    Dec 2008
    Ah thanks for the link. I get a little better understanding now.
    Bigger
    Good:
    * Slightly less friction
    * Longer chain/sprocket life
    * less chain tension
    Bad:
    * Slightly heavier
    * Chainstay clearance may be a problem on some frames
    Smaller
    Good
    * Slightly lighter
    * More log-jumping clearance
    * More chainstay clearance
    Bad
    * Rapid chain/sprocket wear
    * Greater chain tension (increased liklihood of the axle slipping in the frame)
    Over the bars...
    I started to copy/paste this but then got lazy and posted the link instead. Good on ya!!
    offroader
    Dec 2008
    Has anyone noticed any other difference besides the ones mentioned here? I sort of get the feeling that a bigger (34T) front ring causes my legs to rotate slower compared to a smaller ring (32T). Is this in my head?
    Reputation: asphaltdude's Avatar
    Quote Originally Posted by CupOfJava
    If the sprocket in the rear stays the same size, your legs will rotate slower with a bigger ring up front.
    Ride more!
    offroader
    Dec 2008
    Quote Originally Posted by asphaltdude
    I guess it's in my head then.
    Reputation: nuffink's Avatar
    Feb 2010
    Bigger cogs have more chain wrap and are less likely to skip under pedalling. Sheldon Brown and others suggest going no lower than 16 teeth at the rear. Shimano seem to agree.
    I am Walt
    Reputation: waltaz's Avatar
    Size of rings, cogs, wear, etc. aside, the difference in the ratios is the gear inches - the measure of how much "work" you do. The formula is as follows:
    Front ring / Rear cog x wheel diameter (26 or 29) = gear inches (measure of how far the wheel goes with each pedal revolution).
    Examples:
    29'er: 32 / 18 x 29 = 51.6 gear inches
    26'er: 32 / 18 x 26 = 46.2 gear inches
    29'er: 34 / 18 x 29 = 54.8 gear inches
    This shows why the same ratio on a 29'er vs. a 26'er is "harder", and why, to CupOJava's question, the bigger front ring causes his legs to rotate slower...it's a taller gear.
    Ride more; post less...
    offroader
    Dec 2008
    Quote Originally Posted by nuffink
    Ah thanks, so that's why the magic gear ratios seem to be 32-18 and 32-20.
    Monkey Junkie
    Here's the gear inch calculator I use: http://software.bareknucklebrigade.c...it.applet.html
    comes in handy sometimes when trying to get the best gear inch with the variety of cogs/rings I have for different bikes.
    Reputation: boomn's Avatar
    I can't say its a huge difference, but I've been using a 36t front ring for a while and it feels a bit nicer and seems to be holding up well.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Gear ratios- something for SSers to fuss about besides which alt bar they want and whether to have susp or rigid.
    Maybe I come from a different riding perspective, but if my chainring will hit something on the way over, it is time to walk.
    I'm thinking of upping to 42t in the front.
