Gear ratio- Mtbr.com
Results 1 to 8 of 8
Thread: Gear ratio
    Singlespeed Enduro Poser
    Dec 2009
    Caution;  Merge;  Workers Ahead! Gear ratio
    Folks,
    I'm currently running a 32:20 gear ratio and was looking to make it a tad more difficult. Which would be the harder gearing.
    33:20 or 32:19?
    Thanks in advance.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    Everything you need to calculate is here:
    http://software.bareknucklebrigade.c...it.applet.html
    Birthday Collector
    Reputation: ATBScott's Avatar
    Scott forty G; Without getting into the calculators, a good "rule of thumb" is that if the front ring has more teeth than the rear cog, that making a change to the rear cog by one tooth will affect the gearing more than making a change to the front by one tooth. Therefore, the 32:19 will be a little bit taller gear.
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Quote Originally Posted by ATBScott
    Not only is this guy totally right but it is also cheaper to buy cogs than chainrings.
    no chain no gain.
    Birthday Collector
    Quote Originally Posted by 10speedbiopacefreewheel
    And you're right too - I wasn't even thinking of the price factor.... Though if your front ring is worn, and your rear cog is in good shape, a 32:19 and a 34:20 are nearly identical.
    Reputation: Van-Go's Avatar
    Yes
    Quote Originally Posted by driver bob
    Man! Thank you! That's very helpful!
    Dec 2009
    Thanks all. I will settle for 32:18
    Reputation: ruylopez's Avatar
    Jan 2009
    I'v ran 32X18 for along time and smoke my buddies that are 32X20. Thinking about going back to 16 little tuffer on the climb but super fast on the flats.
