Gear inches- Mtbr.com
Results 1 to 7 of 7
Thread: Gear inches
    surly inbred
    Reputation: TroutBum's Avatar
    Gear inches
    My parts bin looks like a ****ing cassette factory projectile vomited in every corner. What that really means is that these days I tend to count inches, not teeth.
    How much change must you input to detect change?
    Yes, I'm a ****ing ***** trying to decide how far I can go without losing my mancard. Or, really I just want more climbing ability without giving up too much on the other end. Or, Or... I might want to buy a cog and need the masses to make up my ****ing mind. Anyone else need a beer?
    Not a good rider here. I can feel the difference in 2T. Funny thing is that, I don't feel that big of a change when I was riding geared. I used to pop a few gears at one go.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    I have 16, 17, and 18t cogs and have my favorite for all my local trails, so yes I can tell the diff. But since I went to a threaded hub, I stick with one WI FW since those things are goddamn expensive and a betch to change out.
    Mar 2012
    +1 beer (left hand milk stout)
    What gearing are you running? What elevations are you hitting?
    Have you thought about "cheating" and running a dingle setup with two different gearings that allow quick swap? The 4 tooth rule could let you swap quickly if you don't need a big ratio change..
    Spandex Ninja
    Reputation: webb-o's Avatar
    Recently went up 5.5 gear inches (46.6 to 52.1) on my 29er. Roughly equal to subtracting 2 teeth in the rear. It is definitely noticeable. I am doing my typical loop about 10% faster than before with this gearing, but the technical climbs are noticeably harder (but not impossible).
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Bring a sixxer or doughnuts to your local mechanic (*hint* the local mechanic in Canton prefers the latter) and discuss.
    +/- on cogs are much more noticeable; rings are more subtle.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Blow out the sand and go for a ride. Repeat as necessary.
