Gates Beltring (39 tooth) + XTR 970 fit problems = Anyone use XT?- Mtbr.com
Results 1 to 11 of 11
    Reputation: illcomm33's Avatar
    Just ran into a snag during a build last night.
    The 39 tooth Gates Carbon Belt Ring would not fit on the my XTR 970 crankarms! The spiders are too tall and won't allow the ring to sit over the spiders.
    I checked the Spot Brand site and noted the 39 tooth SS belt drive Rocker uses a Stylo crankarm....so that is one option.
    Anyone use a Shimano XT 770?
    Yep I am a Shimano guy for life!
    grinder time.
    ______________________________
    "If it ain't moto, it's worthless"
    Out spokin'
    Dec 1999
    Quote Originally Posted by nmanchin
    grinder time.
    Not so fast... different bcd's... aren't they?
    --sParty
    disciplesofdirt.org
    poor excuse... still GRINDER time!
    Grinder TIme: Not a chance. :)
    --sParty
    The BCD's are the same...it is the flange on the beltring and the higher spider arms....The pic doesn't do it justice on how close it really is. It is close...but still not grinding.
    Update
    Stylo OCT 1.1 crankset: Works fine
    Spot Brand SS crankset: Works fine
    Right now I am using that Spot Brand Crankset since I can keep the King BB. (No GXP)
    Teen Wolf
    Reputation: cr45h's Avatar
    scrap the belt and move on!
    So you have an XTR m970 crankset for sale?
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    so you have an XT 770 crankset for sale? ^^^^^^^
    "If women don't find handsome , they should at least find you handy."-Red Green
    Feb 2006
    The 39t will fit on the m970 arms. I had to file down the tops of the of the chain ring tabs. It took about 5 mins to slightly file down the tabs. Once you evenly file down the tabs you can get it to fit.
    Here's mine on my Trek Sawyer.
    Gates Beltring (39 tooth) + XTR 970 fit problems = Anyone use XT?-sawyer-belt-drive-640x478-.jpg
    Thanks for all the posts. And for the record the cranks are NOT for sale.
    It appears a little a little sanding on the tabs will do the trick! Thanks all.
