Full Suspension SS ??????- Mtbr.com
Results 1 to 164 of 164
    Wax
    Wax is offline
    Reputation: Wax's Avatar
    I know, I know, singles are supposed to be rigid and painful but I have an idea anyway. Has anyone ever heard of or tried out a single with a suspension? maybe like 5" of travel. I know their are inherent problems with the chain but what about designs that pivot around the bottom bracket shell? Could you use a bike with this design, add an old derailer to hold a little extra chain and make it work? I'm getting a little sick of adjusting the tranny on my all mountain bike and often take my single out just for simplicities sake.
    Thoughts?
    Hoopy Frood
    Reputation: khill's Avatar
    Kona A
    Kona makes a full-suspension singlespeed frame: the "A'
    Kona Frame Shop
    You could convert a full suspension bike but you do need to use a tensioning device which can adjust for the chain slack as a result of the suspension movement's effect on chain length. An old derailleur would work fine.
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it. - Thomas Jefferson
    75% Mountain cycle
    Reputation: SanAnMan's Avatar
    A search should yield some pics
    Do a search, this topic has come up a fair bit. It's a cool idea I've often thought about. I've see FS Kelin Mantra SS's, Catamount SS's, lot's of softail pivotless designs, and others. Mostly have URT or pivot around the BB. Pedal bob will be your worst enemy on a SS so look at a stable platform shock if you do a convert or a Kona A.
    If you convert a regular FS bike, you'll not only need a tensioner but I'd suggest something like chain guides to keep the chain on the rings. (sandwich them)
    Below is a convert I did last year with an old derailleur as a tensioner but I lost the chain on every rocky descent. I shortend the chain and I came up with some chain guides to sandwich the rear cog and front derailleur and it worked great. I hated the chain slap though. If I had a load of cash - I'd do one of the DEAN Ace frames with the pivot aroud the BB.
    Reputation: itsdoable's Avatar
    Been SS'ing this for quite a few years:
    If you search FS SS, you'l find others.
    Not a Barry supporter.
    Reputation: Crash_FLMB's Avatar
    Here's mine. I've been riding it for only a few weeks now. I swapped the fork with a Marz Marathon S and it's much nicer. A better balance b/c I can make it a little more stiff to make up for the bob. I have a lock out on the rear shock so when climbing I just use that. I've also shortened the chain by a couple of links and it seems to be holding better of late. Once I get a non-ramped front ring, I think all will be well.
    There are other more detailed pics somewhere on this board too.
    Why would I need more than one gear?
    @A_SingleSpeeder
    EPA = crooks!
    Reputation: pacman's Avatar
    Been there
    My old full suspension SS. I converted a GT i-drive to SS, and turned the rotating BB into an EBB by removing the suspension link, so no tensioner was ever needed. Eventually the frame cracked and I bought a Unit.
    {other picutres somewhere in the archives}
    Devolution is real!
    Reputation: toyota200x's Avatar
    PACMAN.............
    Holly crap I am in love with that GT full suspension....I never really got how that I drive stuff worked but I love the look of that GT. Where did the frame crack? Please post some more pics of it. Lets turn this thread into a full suspension pic thread. I also love the pro-flex, there is something so unique about a FS SS.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Wax
    I know, I know, singles are supposed to be rigid and painful...
    You are mis-informed. Rigid does not necessarily mean painful and singlespeeds do not have to be either.
    mtbtires.com
    What day are we riding?
    Reputation: Rockin's Avatar
    I used to have two Schwinn Homegrown FS singlespeed bikes - URT design. They worked great.
    Now I have a Lenzsport that uses the concentric bottom bracket pivot point.
    Reputation: Mudflaps's Avatar
    Quote Originally Posted by shiggy
    Amen to that Shig.
    Quote Originally Posted by itsdoable
    Nice bowti
    Formerly DMR For Life
    Reputation: Full Mountain's Avatar
    Mar 2005
    correct me if i'm wrong but they used to make (unless they are still making 05's)...no A for 2006 at least not as a frame alone...and doesn't look like as a fully assembled either
    DMR
    Reputation: noslogan's Avatar
    agaaaiin?
    It usually gets attention. Not too many FS SSs out there.
    Some pictures
    Cracked at the weld, usual failure I suppose.
    The EBB, drilled and tapped the i-drive for set screws to lock the EBB.
    Rode it all over the place, including epics.
    Reputation: Thylacine's Avatar
    One of my aims for 2006 is pull a FS SS out of the bag. At this stage I'll probably end up doing a very unfashionable steel URT.
    Well, someone has to do it now that Ibis has turned to poo.
    Anyway, who said SS had to be about simplicity? Honestly, its about having fun and hurting yourself senseless.
    Oh, and beer.
    No longer member of the bike industry nor society, so don't hassle me.
    Medium?
    Reputation: Fast Eddy's Avatar
    Mmmmm...
    May 2005
    Fisher Joshua FS SS
    Thoughts?
    I recently converted my old Fisher Joshua F1 to SS. It has the URT design so chainline length issues are not a problem. It allso has an older SID rear shock with on the fly lockout. I think you kind of need it on a FS SS even with a stable platform shock (My 05 Dawg Primo has it). I have to say that I love to ride this bike as every time I hop on it, it's like an old friend but, if I were to build a new SS I think I would build a hardtail. I am finding that I am riding it locked out more than not.
    Quote Originally Posted by khill
    Kona Frame Shop
    These were sold out 6 months ago. Both shops and kona's website. There was a 16" on mtnr classifieds about a month ago, and a few 18's on ebay 2 months ago.
    Anyone have pics of the new '06 model? Its not in the 06 frameshop lineup. I heard rumor of it being at interbike, but no pics yet. I was told by kona via email that there is a US only version of the A frame due out this fall. Haven't seen it yet. Im getting real close to buying a Lenz if I don't hear SOMETHING about the Kona A real soon.
    Nevermind. Found it.
    '06 A frame from interbike
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    i suppose you could make any hardtail SS into full suspension with a Cane Creek Thudbuster...3" of travel and no chain adjustments...just not so great in the cold cold months.
    Expert of the Internet.
    BECAUSE I SAID SO
    Eric the Red
    Reputation: edoz's Avatar
    I did it like this...
    My Titus Motolite was ss for a bit
    Devolution is real!
    PACMAN........
    WOw that is quite the crack. What are you riding now?
    Lets keep those pics comming I love looking at them.
    Wax
    Wax is offline
    how did the titus work? since you said an SS for a "bit" I'm guessing not quite perfect?
    Eric the Red
    It worked quite well actually. I did it for one race as kind of a novelty. I left it that way for a month or so, but I put the gears back on and hung it back in the garage where it has been since I got my new Dambala. In March.
    Sep 2004
    Here is Spider SS @ 4", retired it 3 months ago, after 1 year service, no problems. Now riding 5" version will post pic later.
    Devolution is real!
    n10'sGUY
    That is a crazy nice bike. I love those Raceface cranks.
    wait a minute....
    Reputation: SIGMA's Avatar
    works ok
    wont bob,flexes a little.
    Manual4ever
    Reputation: Prime8's Avatar
    The pic I got from Kona frameshop the bike was called Cowan not A
    name change? I dunno but i'm trying to order one right now!
    The A didn't seem tough enough for DJ/Street but this one looks sweet!
    linkage: Kona Cowan
    www.ntxbmx.com
    Jun 2005
    Fr-ds-ss
    A few months ago I saw a Freeride Dual Suspension bike at bikes in more in dallas, I think it was a an intense or something like that, no tensioner. It stuck out to me because I only saw the brake levers on the bars. It looked pretty sweet.
    www.ntxbmx.com North Texas BMX
    Dec 1998
    Quote Originally Posted by Prime8
    linkage: Kona Cowan
    Different bikes. The 2006 "A" has not been posted yet and it is a XC frame. The Cowan FS is the jump bike.
    mtbtires.com
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    Nice!
    Dude, you have a POOL?
    I'm there.
    JMH
    Quote Originally Posted by noslogan
    www.ntxbmx.com
    Jun 2005
    The old Cowan was pretty Rad, the new one with DS may be as well, but I think its ment to be geared
    Manual4ever
    Quote Originally Posted by jherich
    it's simpy an A with the Kona Clump front end, sliding drop outs and a pivot around the BB
    Whaaahh!
    Quote Originally Posted by JMH
    I'm there.
    JMH
    I hate looking at that picture. It is not my pool.
    Devolution is real!
    Here is another sweet FS SS.
    Quote Originally Posted by toyota200x
    Sweet toyota200x! I love my Sugar SS. I truely think GF could market it as a FS SS. Since I got the chain legnth figured out, I've only dropped it 3 or 4 X's. That's riding it twice a week for about 6 weeks now. Not too shabby! Plus I threw my Marathon on it and it rides even niver now.
    @A_SingleSpeeder
    EPA = crooks!
    Reputation: PekkaP's Avatar
    Dec 2004
    mine
    Bring On The Spine Bender
    Reputation: upstatesspdr's Avatar
    Dec 2005
    Ok, I had to get in on this-how about some riding impressions on the Kona A ?
    I t looks like a great idea,is weight a concern ? I am sold on the idea of building up a short travel SS ,either using the A or taking a geared frame and converting it.
    I think the old Trek Y bike might work well also,has anyone tried that?
    By the way,I currently ride a couple singlespeeds a Gt hardtail and a rigid Gary fisher (steel)
    By the way I'm new to the board here, so hello to you all
    Sep 2004
    Nice pool, it looks like the back drop for a porn movie.
    I'm sticky
    Another GT conversion - my '93 RTS-1. Not FSSS though... rigid fork... RSSS.
    Evil Lurks
    Reputation: Davetoo's Avatar
    i-drive singlespeed
    Here's my contribution. i-drive ss, just took the dogbone out, pulled the eccentric tight, and locked it in place with some 2$ hardware from The Home Depot (big saturday planned - wasn't sure I'd have TIME.)
    It bobs a little, esp when you stand and hammer on it. Pretty fun though.
    Dec 2005
    Our local shop here in Charlotte NC has a used Kona A frame for sale.
    Wax
    Wax is offline
    Quote Originally Posted by Scott T
    what size and how much? can I get a phone number?
    Dec 2005
    South Park Cycles
    704-522-7006
    Devolution is real!
    Nice bikes.
    Reputation: Paco Finn's Avatar
    What is the weight on that frame? How does it ride?
    Thanks,
    Nate
    Paco the "Flyin' Finn"
    conjoinicorned
    Reputation: ferday's Avatar
    don't forget the cove g-spot, great FR/DH singlespeed...
    what would rainbow unicorn do?
    Reputation: Ride_MD's Avatar
    Jan 2005
    Trek Y-bike
    I've seen them ss'ed before
    Peter- Oh My God! There's a hidden message in my alphabits!!
    It says: OOOOOOOOOOO
    Louis- No Peter, those are cheerios
    Devolution is real!
    More FSSS
    Manual4ever
    not for XC!!
    Here is another.... Brooklyn Machine Works Looks heavy but strong!
    For me this bike would be perfect...
    Devolution is real!
    Those are some neat looking bikes.
    75% Mountain cycle
    Another Klein Mantra
    Not my bike. Found photo on old CD I burned in 2004.
    Reputation: bikeny's Avatar
    Catamount URT frames for $144!
    If anyone is looking to make a FS SS from sctratch, I just saw some Catamount URT frames at Cambria. They are $145 for the frame only and $499 built up with crappy parts. Might make a good start to a cheap build. The dropouts look very meaty, you could probably even do some dremel work to run without a tensioner. I have no stake in Cambria, just passing on the info!
    My FS SS is 40 years old
    ... and it's a road bike
    I have heard that the Giant Trance has only about 1mm of chain growth throughout its suspension arc. This is close enough for a SS conversion.
    (My road bike is a Moulton)
    "The man is richest whose pleasures are the cheapest" Henry David Thoreau (obviously a single speeder)
    "...everytime you throw something away your load gets lighter..."
    75% Mountain cycle
    Haro Sonix begs to be SS
    BB pivot make the new Haro Sonix a candidate for FS SS. Plus - stable platform makes it ideal for SS. I hope to see one of you enterprising SS'rs make it happen.
    What's that smell?
    Reputation: phxartboy's Avatar
    Dec 2005
    True Dat - Double true
    mine...<p>
    <img src="https://gallery.mtbr.com/data/mtbr/502/medium/27596306KonaA.jpg">
    Reputation: 'fiend's Avatar
    May 2005
    Thoughts?
    I recently skimmed the "Horst Link" patents and was surprised to see that all the claims require multiple gears. So it appears someone could make and sell an SS bike with a Horst Link without having to pay royalties to Specialized. Perhaps you'd need some kind of tensioning device though.
    The Kona A looks pretty nice. What is the full deal on that bike, I have not been able to find much information on it. Is it hard to get one of these frames? Is there an 06 version coming out? Any general reviews?
    Go to konaworld.com
    Plenty of info...
    Jan 2005
    Quote Originally Posted by Rockin
    that's a hot bike..nice
    "He can make even a global summit meeting seem like a kegger." M. Dowd, NY Times, 19 July 2006
    What's that smell?
    Quote Originally Posted by capun_canuck
    I have an 06. They didn't put it on their site in the Frame Shop because they are not selling it in Europe. At least that's what Kona told me...
    Manual4ever
    Try the Cowan DS... basically the same bike, but with a 'clump' from triangle
    Just contacted a local shop, and they said kona only has the 2003 A frame in stock, and that the price would probably be around $1000 (just for the frame). hmmm that seems a t'wee bit pricey.
    Reputation: KleinKrazy's Avatar
    Feb 2006
    Here's mine >
    It's an old pic posted before by TheRedMantra. I used it all through last summer - it's funny how people laugh at it at the trail-head. They don't laugh when I blow by 'em on the trails, though I'm slowly working on an SS Attitude as we speak, amongst other things.
    If anyone wants pics of anything in my profile, feel free to message me. I haven't been on this site in at least a year.
    75% Mountain cycle
    work of art!
    She's a beauty - good work!
  67. #67
    What's that smell?
    Can I not delete a post?
  68. #68
    Wax
    Wax is offline
    catamount URT
    I as well saw that frame and am interested. has anyone heard anything about this frame? the postings on the reviews look promising. I'm afraid there may be pedal bob though. Any thoughts before I pull the trigger?
    Quote Originally Posted by bikeny
  69. #69
    Mar 2006
    FSR Single Speed
    I'll have some pics up soon of my '99 fsr full suspension singlle speed. I should have it built this weekend, as the fork just arrived. I'm using the Melvin. It is all blue...hehe...
  70. #70
    Reputation: Bullit_cn's Avatar
    I ride a rigid SS for the reason that I hated Bob...Now this FS SS is quiet interesting...how do you ride a FS SS bike compare to a rigid one specially on the climbs???
    When trails gets tougher, Just stand up and deliver.
  71. #71
    Mar 2006
    SS Blu
    She'll be more blue as the year goes on...cranks, wheels, etc..
    Pretty light at the moment, but could be a few hairs lighter...have to balance between blue and light sometimes. Yeah I know...
    Do they make Crossmax SL's in blue...lol!
    For more detailed pics, check: HERE
    Bonne Chance a tous!
  72. #72
    75% Mountain cycle
    carbon softy
    I found this pic from 2003. No idea who's bike it is but it's Sano!
  73. #73
    SanAnMan, can you please post where you found this and any info? THIS is the one I've been looking for! Can anyone see the website on the chainstay? Thanks
  74. #74
    Feb 2006
    I've been spinnin around on my Stumpy FS 30yr anniversary Special ed for a couple years. Built it back to gears and picked up an 06" Stumpy. Can't go wrong with a Fox Triad propedal and Talas RL 130. 5 and 5.
  75. #75
    Feb 2006
    Didn't upload the first time. I've been spinnin around on my Stumpy FS 30yr anniversary Special ed for a couple years. Built it back to gears and picked up an 06" Stumpy. Can't go wrong with a Fox Triad propedal and Talas RL 130. 5 and 5.
  76. #76
    singlespeed smash brother
    Reputation: shwinboy's Avatar
    Quote Originally Posted by Helibee
    That bike is a newzealand brand called Lahar. They don't make them any more. I tried to get one just after they closed.
  77. #77
    Reputation: mt bk's Avatar
    Trek Y Bike Finally pays off
    Well, it's a pretty ugly bike, but it is a FS SS. I feel a little silly riding it around, but its a comfy bike when the hammering gets rough.
    Is it lame to ride a FS SS?
    Just Ride!
  78. #78
    75% Mountain cycle
    Dated 4/18/2003
    The pic is dated 4/18/2003. It looks like someone has the name and model for you here in this thread so you should be golden. Sorry I can't help more.
  79. #79
    Thanks SanAnMan and shwinboy. I was able to make contact with Lahar who informed me their molds had mysteriously disappeared a short time ago. They have started up production ounce again and I'm checking on availability. I think this wouild make an awesome FS/SS 29er. Too Cool!
    Thanks again.
  80. #80
    Reputation: sholack's Avatar
    Thanks again.
    Thats a FS? how? maybe I am just no seeing the invisible shock and links in there... looks like it would just snap when the going got rough... one hell of a sweet looking bike though!
  81. #81
    Quote Originally Posted by sholack
    It has flexable chain stays. It has about 1 -1.5" of deflection. In reviews I read they said it also twisted on off camber trails but couldn't say if this was a bad thing. I would have thought it would cause chain drop issues myself. Any way Lahar have been out of buisness a couple of years now which is a pitty since they had this bike and a very nice and light carbon G box Dh bike. I think the guy went back to building Cf parts for racing yachts.
  82. #82
    Blanco
    Looks like about 6" travel on this SS beast:
    http://www.rambikes.com/CP/freeride.html
  83. #83
    scalpel ss
    i did a race a few weeks ago in hanson hills, michigan. i rode a good portion of the race behind a scalpel ss. i happen to have a scalpel that i hardly ride anymore due to the fact that i've gotten into the 29er ss with a gary fisher rig. i'm thinking that may be a good project for the winter. if anyone has any tips for the conversion that would be great.
  84. #84
    ups and downs
    Just hammered this one together in June. It is a hoot, on the same trails as my Kona Unit it just rockets over rough stuff where you'd normally have to stand and ride out the root carpets. Kona has/had some 20" 2003 A frames with V-brakes only and horizontal dropouts left in Vancouver. I got this one thru Cove Bikes. There's a bit of bob with standing climbs but oddly enough it seems more comfortable. It hooks up much better on climbs than the Unit did. I think my Unit is now obsolete.
  85. #85
    Reputation: LarryFahn's Avatar
    Quote Originally Posted by shwinboy
    They're still around. http://www.laharbikes.com/
    Ugly as hell, but....
  86. #86
    ups and downs
    I have a 2003 Kona A that is setup as an SS and a 2006 Kona A that I am running with a Rohloff rear hub, and the one thing I do find as a difference between the two frames with two different shock lengths with different rocker ratios is the amount of pedal induced suspension compression. If I start off in too big a gear with the 2006 A, I can slowly push the shock through a lot of travel, it really squats. When I'm standing and grunting on the 2003 A with a 34:18, I don't get the same degree suspension squish. Both bikes have Fox RP3's.
    The amount of pressure required to get 25% sag on the 2006 A is much less than the 2003. I run about 200PSI in the '03 model to get 25% sag. I run about 165PSI on the '06 to get 25% sag. Even running 25% sag and lower pressure in the shock, the 2006 A seems to have less small bump compliance.
    The 2003 with 3.5" of travel and 6"x 1.5" travel shock has a suspension ratio of 2.33:1 and the 2006 with 4" of travel and a 7.875" x 2" travel shock it's a 2:1 ratio.
  87. #87
    Doesntplaywellwithmorons!
    Reputation: DeeEight's Avatar
    Did it lastyear...
    <img src="https://yoda.densan.ca/kmr/bikes/catss1.jpg">
    <img src="https://yoda.densan.ca/kmr/bikes/catss2.jpg">
    <img src="https://yoda.densan.ca/kmr/bikes/catss3.jpg">
    <img src="https://yoda.densan.ca/kmr/bikes/catss4.jpg">
    I unfortunetly had a ringbolt loosening/falling out incident this spring and destroyed one of my fave 34T rings. Now I'm running an Onza Buzzsaw 34T ring on it, which weighs about twice as much. Its a 19T uniglide cog on it, and the first time I rode it on a paved bike path after turning off a gravel trail, I went to reach for the non-existant thumbshifter...
    I don't post to generate business for myself or make like I'm better than sliced bread
  88. #88
    Gravity addict
    Reputation: yakuzafreerider's Avatar
    full suspension single speed
    I have a 05 iron horse yakuza aniki, I have a manitou sherman slider plus 170mm fork and 130mm of travel on the rear. I'm not one for changing alot of gears so on my downhill/freeride bike I put a race face evolve ss crankset on it. Ive had a lot of other riders look at me like and say you have a dhill freeride bike why the hell are you doing that? well it just works better for me. I do not think I'll go 100% single speed but im looking at turn my bike into a 3 or 4 speed and eliminate the gears that I do not use. I say its about the rider and how they feel on there bike, so if you want to go sspeed go for it if you don't, don't...but a full suspension single speed??? why not if i had more leg power I'd probably try it.
  89. #89
    large member
    Reputation: mud'n'sweat's Avatar
    Feb 2006
    Quote Originally Posted by yakuzafreerider
    Nice, my neighbor has the same bike and the same cranks he recently installed. Come to think of it, I think he said he was getting a slider too....wait, is your name Travis too?
    #1 NORBA elite singlespeed toolbag 30-34 age group
  90. #90
    Gravity addict
    Mud'n'sweat
    Yes its me lol...I went down Bald mountain saturday and my bike setup felt perfect. The fork is awesome, the bike felt like it was begging for more rocks, air, and ruts n stuff. Best part is that I didn't break any bones this time and comparing riding time from saturday to the first time I rode it...man I shaved 2hrs off how long it took the last time, my friend and I cleared it saturday in 1hr 40minutes not bad for a 10mile ride compared to almost 4hrs the first time. The sand gave me lots of hell though, I'm thinking of how to remedy that issue but I think its really a lack of leg strength...lol The crank being a single ring was perfect I didnt miss the other gear. I do wanna get rid of some of the rear cogs but that will be in due time. Didnt you say you won a ss frame? hows it coming along? drop me a line sometime...travis
  91. #91
    large member
    Feb 2006
    What's up Travis! So it is you, too funny how I figured that one out
    I've been wanting to get up with you, but I'm always at work when you are at home and it ends up being too late to call by the time I can get a chance. I got your last message around 10pm that night when I got home. Ellie and I had taken our bikes out for a ride down to the ice cream place on main st. and the light was still on in the garage.
    The frame is coming along great, it is a 2006 Kona Explosif. I've had it built up as a SS from the get go and have put about 100 miles on it already.
    That Bald Mtn. ride sounds great. We need to do one of those rides soon...perhaps even saturday? I'm going to be out there already with some friends so I could skip out to ride for a while.
  92. #92
    Gravity addict
    Sat would be great, but before I could say a definite I'll have to see if my parents would watch my son for me. Charity is going to be at kings dominion saturday with her cell group from church. Can you give me an idea of what time you wanna put the rubber to the trail? and I'll work around that. Well I'll check back around 230pm tomorrow and see if you dropped me a line. Have a good night.
    travis
    How's that dirt taste?
  93. #93
    large member
    Feb 2006
    Timing is a good question, not sure what the plan is with everyone who is going out to sherando. Give me a call tommorow and we will hash it all out. For now, we should relinquish our thread jacking abilities and keep drooling over the FSSS's in this here thread
  94. #94
    Exclusively Single
    Reputation: long hazy daze's Avatar
    I've never ridden one, but it seems like it would be self defeating. Full rigid works well with SS because there's no suspension to soak up the energy from your pedal strokes, so it seems like a FS would sap much of your energy, which is not what you want especially when you're climbing.
    But I suppose if you're one of the shuttle up, bomb down types, running a FS with a big gear would make sense.
    Just doesn't seem to make sense from an efficiency standpoint.
  95. #95
    Here's mine- absolute blast to ride! There's a thread on it here:
    http://www.ridemonkey.com/forums/sho...d.php?t=162221
  96. #96
    large member
    Feb 2006
    Nice Honus, I was actually thinking of posting yours over here myself.
  97. #97
    Gravity addict
    this is a picture of my downhill /freeride bike, im not looking at making it a complete single speed, more like a 3 or 4 speed....gears i hate them, bikes just come with to many!
  98. #98
    Feb 2005
    my brooklyn tmx in ss mode:
  99. #99
    75% Mountain cycle
    Bringing it back
    Saw this pic - kinda FS.
  100. #100
    Reputation: y33dave's Avatar
    Raleigh Ram 1500 XT - FS SS
    So I went to Bicycle Village a few weeks ago... you see - it was their annual 'tent sale' - in hopes to find a decent price on a road bike for commuting.
    Well after deciding I didn't want to spend $800 on a entry level road bike - which I couldn't convince myself I would find the time to ride - I took one last minute to look at the rental returns.
    Low and behold - there sat a 3 year old Raleigh Full Suspension bike - all the parts were there (XT - LX components + hydraulic disc, etc) - some needing work - but what the heck -
    how much I ask... $99 As IS they say! --- I'll take it !
    3 weeks and about $300 later - I now have a FS/SS
    • I had to get the rear shock rebuilt ( which manitou/answer did for free )
    • I took the shimano disc brakes off and put them on my GT I-Drive Race ( all I had to do was add pads and bleed the brakes)
    • Bought a set of Avid BB7's off craigslist
    • And a set of Shimano/Sun Rims from Performance
    • A Forte chain tensioner
    and viola - it's a bonafide Single Speed commuter!
    KICK A$$!
    Dave
  101. #101
    S-works Epic SS
    Here is my Specialized Epic I converted last year. I now use a melvin chain tensioner, it rode well without one. The brain shock is well suited for SS as it doesn't soak up much energy will riding.
  102. #102
    Nov 2007
    ... and if we just ... full suspension conversion
    converted a 2006 specialized fsrxc pro to singlespeed about 2 months ago,this bike rips the singletrack and I have been frustrating and confounding my friends with there gears. I trashed my derailure on a rocky technical trail in the middle of an epic ride, so I had to single speed it or walk, fortunately the fsr suspension does not grow or shrink the chain thru its travel so it worked almost perfectly, ocassionally on a steep climb it would skip the chain off on bumpy sections, I fixed this with a surly tensioner and now it works perfectly. used it for a few weeks with my cassette then ordered a ss conversion spacer kit , I ordered a 20tooth cog but it was not compatible with the 9 speed chain, so I pulled the cassette apart and took the 23 tooth gear since I do alot of nasty climbs , combined with the 32t middle chainring up front , I would say this is the right combination for tough singletrack with lots of climbs involved, I still have the triple rings up front since I plan to switch back to gears in the spring, but for now I am enjoying the singlespeed experience, learning to overcome different obstacles and terrains without the option of an easier gear will definitely improve your riding skill. will post some pics soon.
  103. #103
    one chain loop
    Reputation: fishcreek's Avatar
    prepping for spring
    i got myself hooked to fsss, i think my rigid will be collecting dust this year.
    everything sucks but my vacuum cleaner.
  104. #104
    Quote Originally Posted by Pete Gurney
    I have a Giant Anthem that I turned SS. I love it! First time I converted it I used the Forte SS Kit. Forte is Performance Bicycle's house brand. The tensioner that came in the kit didn't work very well, it allowed the chain to flex too much and after I broke two chains I decided it wasn't worth it, so I ran a 1x9 setup. Also, the cogs that came in the Forte kit don't fit my chain...the only thing useful is the spacers. (I also have a Forte carbon bar, which I love)
    But recently I bought a Yess ETR-V chaintensioner w/the full suspension kit. It's not cheap...it was $80ish including shipping, but it works GREAT. It's very well made, and it's nice and light. There is however one BIG problem I discovered while trying to get my chain alignment right.....the tensioner has to be partially disassembled to get the rear wheel on and off! It's a total PITA...but, I don't get flats that often...but whenever I do it's really gonna piss me off to have to take apart the whole rear end.
    But....I still recommend the Yess tensioner. It works well, and I don't know of anything better available.
    I'll post some pics of my bike later tonight.
  105. #105
    Melvin User
    Heeeeeeer's "Blacky"!
  106. #106
    helllooooooo dream bike!
    NICE MAN!!!
  107. #107
    Devolution is real!
    That Maverick looks so nice.
  108. #108
    Quote Originally Posted by Davetoo
    I'm considering doing something similar with my 1999 XCR 3000.
    How complex is the process?
    I had hoped it wouldn't involved modifying the i drive itself...
  109. #109
    Evil Lurks
    not too tough. shoot me an email and I can send you some instructions.
    davidtevendale at hotmail dot com
  110. #110
    Reputation: jimw's Avatar
    Quote Originally Posted by SanAnMan
    Funny you should mention this. I randomly won this frame in a raffle, and didn't know what to do with it. Then recently a friend let me try her singlespeed, which I thought would suck , but I loved it! I just didn't like the technical descents so much on the hardtail with V-brakes. So I got to thinking about the Sonix VL frame, and that it should actually work well as a full-suspension singlespeed.
    Here's the result:
    It worked great... for 2 rides. I guess I was a little to hard on it :
  111. #111
    trailbuilder
    Klein Palomino with a Rohloff
    Great to see the Maverick SS photos! My ride is not exactly a SS, but I do have just one sprocket front and rear.
    The Klein Palomino is a Maverick wannabe (licensed design), and I wanted to get rid of the derailleurs which kept causing me grief in the weeds and brush where I ride. I first tried to get my LBS (actually Sheldon Brown's (R.I.P) Harris Cyclery) to put on a Rohloff, but they couldn't figure out a way to do it with the funky rear disc brake attachment on the Palomino.
    Luckily, the frame also had cantilever brake bosses, so this spring I finally ditched the rear disc and built a Rohloff rear wheel with a suitable rim for a V-brake. I'm using the Rohloff tensioner with it.
    Up front, I'm using a Surly steel 36-tooth chainring on the outer chainring position (for the 58 mm chainline), with an old larger ring as a bashguard in the middle chainring position..
    Bottom line - the chain tensioner is high enough that it almost never runs into trouble from the brush, and the 14-speed hub, which can shift as many gears as I want even while standing still, is a great match for the kind of riding I do, mostly exploratory on tiny or non-existent tracks through the woods, plus the fast miles on better-known trails to get to the exploratory parts. Sweet riding...
    I think the Maverick frame would be somewhat better, since it can take the Rohloff and keep the disc brake... but I still have not seen a full-suspension bike which will give a great SS/Rohloff ride without using a chain tensioner! I talked with Brian Kelly at Cove Bikes last year about whether they would ever produce a G-Spot with sliding dropouts, but he said the frame designers wouldn't go for it... so sad... but really, the chain tensioner is a compromise I can live with. (While I save up for the Nicolai or G-boxx bike... to move the Rohloff mass out of the rear wheel... )
    I can put up some pix if anyone is interested.
    - Paul
  112. #112
    Pics are always nice!
  113. #113
    Quote Originally Posted by paul.knight
    ... I still have not seen a full-suspension bike which will give a great SS/Rohloff ride without using a chain tensioner! I talked with Brian Kelly at Cove Bikes last year about whether they would ever produce a G-Spot with sliding dropouts, but he said the frame designers wouldn't go for it... so sad... but really, the chain tensioner is a compromise I can live with.- Paul
    This Haro Sonix has been a tensionerless Rohloff bike for a year. The G-Spot can be tensionerless as well. - but this is getting off topic...
    I agree with not having the tensioner, and one solution is to use the TrickStuff exzentriker BB cups - which is also ideal for SS use! Ofcourse it's only useful on FS frames that have no chain growth.
  114. #114
    What's that smell?
    Because I'm an attention whore:
  115. #115
    Reputation: jeffh's Avatar
    Mark Weir @ SSWC08 and his Santa Cruz Nomad
    2nd place !
  116. #116
    Klein Mantra Pro
    Quote Originally Posted by KleinKrazy
    Whats up body, are you selling your klein mantra pro? im interested in it.
    Let me know, Thanx. Arsen
  117. #117
    LW Coaching
    Broke her in with a 200 mile ride this weekend
    <a href="https://picasaweb.google.com/lh/photo/6yzvQb3U8B_8hN2mo_VHAQ?feat=embedwebsite"><img src="https://lh3.ggpht.com/_jV9bjnlfU0k/Sjbo3GHc6pI/AAAAAAAAGOM/AaN4KcT6Lp0/s400/100_1343.JPG" /></a>
  118. #118
    Mtbr Forum Sponsor - Homebrewed Components
    i've got a concept i've been working on that will eliminate the chain and all related issues, so full suspension would be no problemo. just trying to make it cheap/light enough.
  119. #119
    Reputation: newking's Avatar
    Nov 2007
    Does a Dos Niner count? I'm running the Dos softtail as a SS with no tensioner. Best of both worlds - soaks up the bumps on the downhills and pedals like a hardtail on the uphills.
  120. #120
    Lazy People Suck
    Reputation: Fett's Avatar
    Hey that is my old bike and still my same fence. The Merlin Extra Fat was a great riding bike and did well as a singlespeed
    "Son, The world needs ditchdiggers, too"-Ted Knight, Caddyshack
  121. #121
    Reputation: ernesto_from_Wisconsin's Avatar
    Trey Y 33 or 22 frame, ENO hub = ss fool suspension. Ebunk.
    Why? Urt, Unified rear triangle.
  122. #122
    Reputation: Funrover's Avatar
  123. #123
    I build this Kona A last year, it was an old frame.
  124. #124
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I have thought about doing this with my 09 cannondale rize. Just need to figure out what rear shock to put on the back to lock it out and use the the lock out on my lefty PBR to make it a full rigid for climbs but unlock everything for going down. Think its work it?
  125. #125
    the giant.
    Reputation: gbosbiker's Avatar
    im going to convert my kona stinky to ss. its my full on dh rig. i dont need the extra gears. it just skips on drops and rough rock gardens. ill post up some pics when the parts come in. it should be a nice change from the usual rigids and HT ss bikes, and the occasional xc fs ss. i should have the parts ordered in a few days, and then have the parts 3 days later.
  126. #126
    Reputation: scalpelgone's Avatar
    My '93 fsr s-works
  127. #127
    Reputation: fixedforbroke's Avatar
    Dug up from the dead!!! The full suspension SS thread
    Seriously, there is some good bike porn on this thread.
    Req. Disclaimer: I sell Giant, Trek, and Electra bikes.
    Quote Originally Posted by ErrantGorgon
    The no-brainer store called, they want their question back.
  128. #128
    trailbuilder
    Not SS, but Rohloff FS.
    Okay, as requested a year ago, here are a couple of pix of the Rohloff-based Klein Palomino.
    Couple of things of possible interest:
    - I had to ditch the rear disk brake since it used a weird bolt-on adapter which was not compatible with the Rohloff 14-speed hub. (The frame had brake bosses for a V-brake.)
    - The chainring is on the outermost position to get a straight chain line, with a modified large ring in the middle position as a bash ring.
    - This installation uses the Rohloff torque arm (fixed to the fat Klein chainstay using plumbing strap over some chamois).
    Just another addition to the bike porn show...
    Attached Thumbnails Attached Thumbnails Full Suspension SS ??????-palomino-rohloff-1.jpg
  129. #129
  130. #130
    Space Ghost
    Reputation: Coach417's Avatar
    Quote Originally Posted by kardy
    AWESOME! I would love to build something like that. Nice job.
    "No good deed goes unpunished"
  131. #131
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    its going to be nice when more mfg start making dedicated FS frames
    "If women don't find handsome , they should at least find you handy."-Red Green
  132. #132
    got the frame in a swap, old zocchi low-end air fork, profiles that were lying around, generic brakes (WOW do they SUCK, replaced soon) 38x15 magic gear, and slicks for city bombing for now.
    wasn't supposed to be built like this, was built for a friend but she's too short so I tore it down and built it as you see it more out of morbid curiosity.
    if I enjoy it enough I'll find a new magic gear and toss the knobbies back on.
    But honestly, it reminds me a LOT of my old beloved breezer twister so I dunno... it might just stay.
    I call it "bike in most dire need of a working girvin or lawill linkage fork to complete the terminator look"
    Attached Thumbnails Attached Thumbnails Full Suspension SS ??????-schwinnster.jpg
    If steel is real then aluminium is supercallafragiliniun!
  133. #133
    the giant.
    yes. it is a dh bike.
    a pic of my horrible chainline. due to the lack of compatability to run the perfect chainlike with the tensioner and spacers...
    the tensioner has AMAZING tension. its tight as it can be. i could bearly pull the arm when it was of...ill never drop a chain. (i hope. haha)
    the tensioner is the shimano alfine. the spacer kit is the gusset single speed kit. i did this all for $57 with 2 day air from jensonUSA. now i just need a dry day to make sure its good.
    im running a 36-16 ration. i dont know if thats a harder ratio, but it works good on decent hills (when im in more of an all mountain feel) but doesnt spin out at good speed.
  134. #134
    gbos! switch those spacers out to in!!
    may not be perfect but it'll throw the chain a lot further outboard and that's where your chainrings are sitting right now!! should be way better.
    (welcome and toldja there was a FS SS thread somewhere here! the above schwinn is your fault for reminding me!)
  135. #135
    the giant.
    Quote Originally Posted by byknuts
    i would. (i had it the other way when i was running my derailer while waiting for the tensioner to arrive) but the tensioner only adjusts with washers on the bolt. if i ran the spacers the other way, the tensioner wouldnt be in the threads enough...so i flipped the spacers and its lined up. i took a quick spin today and it dint seem to skip or anything of that nature. the tensioner is has a REALLY strong spring.
  136. #136
    the giant.
    Quote Originally Posted by phxartboy
    do i spy 2 chains here??? how does that work? fixed gear? fake chain? whats going on there??
  137. #137
    They market it as a dirt jump bike, but raise the seat and see what happens....
    http://www.konaworld.com/bike.cfm?content=bass
    "Bikes aren't fast--people are fast. Bikes are overpriced. It's an important distinction."---BikeSnob NYC
  138. #138
    trailbuilder
    Bonking ... not feelin' well Cove G-Spot 2010 no longer SS-friendly
    It looks like Cove changed the G-spot for 2010 so the rear suspension no longer pivots around the bottom bracket (so it will introduce chain growth).
    http://www.covebike.com/bikes/gspot.html currently has a computer-generated graphic, but no photo.
    I think the G-Spot was the longest-travel FS frame with no chain growth, even though it was a bit tricky to use for SS, since it didn't have any chain tensioning system.
    It looks like the Kona Bass is the most easily available platform for a FS SS bike now.
    - Paul
  139. #139
    Nov 2007
    Dos Niner
    Here is my Dos Niner Rigid fork SS with 1" rear travel. Set up magic gearing of 32x21 w/o a tensioner.
  140. #140
    Dec 2009
    Why are there two chains on this bike?
  141. #141
    Reputation: mini73's Avatar
    Jun 2010
    Tension on chain
    Quote Originally Posted by lakerfan
    Im thinking of doing this to my Epic also. How did you get the chain tension tight with out using a Chain tensioner? EBB? If so What kind? Thanks.
  142. #142
    Aug 2010
    I like that specialized, some more black instead maybe. It looks like SS's should i think, a large bmx. Just got an old proflex w/ a girvin on it. was gonna make it sorta freeride w/ some urban (speedmax type tires) to it. I couldnt get to the shops in time or i'd prob still doin' something to it. This SS thing sorta does that anyway. (pics soon)
  143. #143
    Reputation: crank1979's Avatar
    Feb 2006
    Here's mine.
  144. #144
    Here you go.
    Intense Spyder full squish one speed. So much damn fun.
    " width="549">
  145. #145
    Bump, simply because I'd like to see more.
  146. #146
    SSOD
    Reputation: Crosstown Stew's Avatar
    Started a thread in Passion about my conversion but prolly should throw some pics here as well.
    http://forums.mtbr.com/showthread.php?t=698335
    Attached Thumbnails Attached Thumbnails Full Suspension SS ??????-img_20110402_101902.jpg
  147. #147
    First generation (the better one) Schwinn Homegrown Sweetspot. Rides great, plenty durable, and only weighs 22 pounds.
  148. #148
    Blue Pig
    Reputation: Blksocks's Avatar
    Dec 2009
    Vitus Sane FS SS
    Ragley Blue Pig
  149. #149
    I hate that name.
    Reputation: blunderbuss's Avatar
    Finally got mine together. 28.74 lbs as it sits.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
  150. #150
    Reputation: umassracer's Avatar
    New question here. Rear Brake?
    Hello 2 all.
    Are the weight & co$t the main reasons that most of the "A" bikes I've seen all have a Linear Pull/V rear break instead of utilizing the disc mounts?
  151. #151
    Thanks to everyone in this thread for the inspiration to finally do a SS conversion on my FS bike.
    All I can say is, I wish I had done it sooner, worked out awesome!
  152. #152
    Reputation: Shalom's Avatar
    Nov 2008
    Friend of mine has an Anthem X single speeded. He is using a Shimano Alfine chain tensioner to avoid issues encountered with chain tension through the travel. Works surprisingly well.
  153. #153
    Fs ss
    Sorry for reviving an old thread, but it was better than starting a new one. And it was cool looking at all the rigs previously posted.
    Rode my FS SS twice this week after a bit of a hiatus since I got a new bike at Xmas time. I missed her and promise to ride her more often going forward. Lots of fun.
    EDIT: Still using the triple chainring as a bashguard
    Attached Thumbnails Attached Thumbnails Full Suspension SS ??????-bike-bridge-double-ponda.jpg
  154. #154
    one chain loop
    thinking of getting my first fsss. i know it is a slopestyle bike, anyone liked the Kona Bass?
  155. #155
    Slack short travel bikes are a huge amount of fun. I say go for it! Now that you have revived this thread I'm inspired to put the Element back together
  156. #156
    makin skid marks
    Realization of a ten-year dream.
    Actually I abhor cycling- I just like wearing tight shorts
  157. #157
    Manual4ever
    Quote Originally Posted by fishcreek View Post
    I have an 05 Cowan DS. I like it, definately not the best, not the worst.
    I would recomend it!
    06 Giant STP
    06 Kona Cowan DS
    07 Giant Bowery
  158. #158
    Mar 2012
    Just picked up a leftover 2010 kona bass for a steal! I love this thing!! It's my commute, trail, DJ, urban assault bike!
    I'd post a pic, but I don't have more than 10 posts! Hold on, I'll fix that
  159. #159
    Cormac
    Reputation: cormy's Avatar
    The year 24hrs of moab allowed single speeds to have suspension vs. being completely rigid, everyone was converting FS bikes to SS. A good friend of mine who was on the winning SS team converted his Trek top fuel to SS.
    '11 Dawes Deadeye
    '12 Niner E.M.D. 9
    '09 Giant ocr c1
    Xtracycle
  160. #160
    Cormac
    Quote Originally Posted by bassteban View Post
    I have one of those bikes hanging on the rack in the garage...maybe it would be a fun project to convert it to SS also
    '11 Dawes Deadeye
    '12 Niner E.M.D. 9
    '09 Giant ocr c1
    Xtracycle
  161. #161
    makin skid marks
    Quote Originally Posted by mountaindudespike View Post
    I am EXTREMELY pleased w/the Scalpel as a SS; I'm still going through(rear)shock & brake issues, but when I get all the bugs out I will COMPLETELY neglect my kids.
  162. #162
    Mar 2012
    Here's my wife's fs ss. Jamis parker 2.0 built up fairly all mountain style..... Weighs just over 28 LBS.
  163. #163
    Reputation: JammerNinerBoxx's Avatar
    All this reading about FS SS has got me thinkin about turning my Niner Jet9 into a SS. Hell I have a Rip geared so I definitely don't need my jet to be geared. Has anyone ever done a jet9 SS?
  164. #164
    Reputation: boostin's Avatar
    After months of having parts sitting around, I finally got everything together last weekend. It rode well up at Priest Lake in North Idaho. Fun so far!
Members who have read this thread: 10
