Full suspension conversion to single speed- Mtbr.com
Results 1 to 21 of 21
    New question here. Full suspension conversion to single speed
    Hi everyone. I want to ride single speed. That's the bottom line. However, I have a 2010 Superfly 100 full suspension bike (not that that's a bad thing). I was under the assumption that a full suspension could not be converted to a single speed. However, an internet search yielded a product from Yess Labs called an ETRD chain tensioner that is supposed to make converting a full suspension bike to a single speed possible, and a review I read says it works great.
    I know a full suspension single speed is not in the realm of "pure" single speed, but I can't afford another bike, and I want to ride and race single speed. Does anyone know if it is possible to convert my superfly 100 to ss using this product. It would be awesome if I could.
    Reputation: amblake50's Avatar
    Nov 2008
    yep
    It is definitely possible with a yess tensioner. A guy in the WORBA series was riding that exact set-up. This also works with the Salsa Spearfish. I think the Paul Melvin will also handle this application.
    If not bikes then what?
    I work in a shop and that influences my opinions.
    Eriksen 29er SS
    ... and if we just ...
    Nice!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Moderator Moderator
    Reputation: 2melow's Avatar
    Quote Originally Posted by mike carmody View Post
    I found an old derailleur in the parts bin to work just as well, but make less noise. A short cage Dura Ace or Ultegra would be ideal. Plus way cheaper if you have one in your parts bin.
    Mine is an original XTR with teflon coated ceramic bearing wheels.
    Attached Thumbnails Attached Thumbnails Full suspension conversion to single speed-img_0398.jpg
    Front Range Forum Moderator
    that bike looks so good
    Beer is my spirit animal
    Reputation: Spinnyspinspin's Avatar
    Dude you should be able to find a complete Redline Monocog (not a flight) for less than 600 bucks, maybe even 450 if you can find an LBS trying to get rid of some older models, and for the price it's awesome! Really great introduction to 29ers, rigid, and singlespeed, all rolled in to one amazing bike!
    I don't believe anything, but I have many suspicions.
    ― Robert Anton Wilson
    Nov 2008
    Most of the tensioners just have move spring tension/ better springs- but that is a sweet set-up
    Eriksen 29er SS
    I've recently converted my old 2002 Specialized Enduro full suspension into a SS. I've learned a lot from reading the blogs and from reading Sheldon Brown's advice after some "trial and error", mostly error. Before reading up on it, I just tore apart a cassette, found a good gear combination, shortened my chain to a nice taught tension and starting riding it. After 3 rides in tough terrain, the cog literally wore off its ribs on the freewheel and was spun free. I now understand that the flexing in the suspension causes the chain to tighten on every compression. So, you need a tensioner to deal with this. The best reviewed tensioners are these YES ones which are $70. I found one by Sette. I'm too new to post the link, but type sette single speed tensioner into google and you'll find it. Or you can send me a private message. It puts pressure down, which is key to full suspension and it was only $18. I've only ridden once so far, but it worked and I didn't lose the chain once. The price was right for the kind of experimentation I was doing.
    Reputation: BeginnerCycling's Avatar
    That's a great looking bike!
    ballbuster
    Reputation: pimpbot's Avatar
    I ran an old road derailleur as a SS tensioner for a while back when I was first getting my feet wet in singlespeeding. I lost my chain A LOT. It was okay, as long as I wasn't pedaling over bumpy stuff.
    If you go this route, I strongly suggest some sort of bash guard and a Third Eye Chain Watcher. At least that will help keep the chain on the chainring up front. I'd imagine that even doing a front derailleur fixed in place would work to keep it under control.
    Yeah, I second the Monocog 29er. There are tons out there used as well. Check Craigslist. I have a bud who just picked up a Monocog 29er Flight for $400. I got my non-flight MC29er brand new for $500 tax and all 4 years ago. Yeah, the price went up a bit since then...
    If you decide you like FSSS, look at the Lenz Milk Money.
    Category Winner
    Reputation: teamdicky's Avatar
    YESS ETR-D worked just fine for me. A bit noisy, but only one chain drop over a period of @ 9 months.
    WWW.TEAMDICKY.COM
    I get paid 3 every time I post on MTBR.
    big legs, small brains
    Reputation: kylemason's Avatar
    One more post to 5000! Get some Dicky!
    Kyle
    Feb 2013
    Hello,
    I am going to convert an old Kona Bear into single speed.
    I have no idea what gearing to use. I will use the bike for commuting and also in the trails. It is not very slopy around where I live, near Paris (France) in fact!
    If any one can indicate where to start and from there I will accommodate?
    Best,
    Alexandre
    There is a wealth of information here....
    Singlespeed Bicycle Conversions
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The classic 26" SS MTB gearing is 2:1, 32/16 for example. For commuting and light trail use a better starting point is 34/16 or 34/15.
    Feb 2013
    Thanks. Gonna try it out soon. Waiting for a half link chain to finish my set up.
    A.
    Lenz MilkMoney
    Not a cheap option. But I knew exaxtly what I wanted
    Attached Thumbnails Attached Thumbnails Full suspension conversion to single speed-lenz2.jpg
    Ohne Jangschalltung
    Reputation: nordstadt's Avatar
    Nov 2012
    That is sweet!!
  1. Single Speed Full Suspension 29er?
    By CarlosMeatPewps in forum 29er Bikes
    Last Post: 03-08-2011, 11:42 AM
  2. Full suspension single speed setup
    By juan pablo in forum Downhill - Freeride
    Last Post: 04-25-2010, 12:05 PM
  3. Full Suspension Single Speed Build complete
    By imapodaddy in forum California - Socal
    Last Post: 01-24-2008, 09:56 AM
  4. full suspension single speed?
    By ssinglesspeed in forum Singlespeed
    Last Post: 04-02-2007, 02:51 AM
  5. full suspension single speed...is there such a beast?
    By oxygenrace in forum Singlespeed
    Last Post: 04-22-2004, 05:06 PM
Members who have read this thread: 12
