FS SS Conversion vs Purpose Built- Mtbr.com
Results 1 to 10 of 10
    Oct 2015
    I've got a question that I couldn't find an answer to searching through old threads.
    Compared to a purpose build single speed full suspension frame like the Oxide Battleaxe, Kona A, or DMR Bolt, is there a drawback to converting a non-ss frame with a tensioner (other than the weight penalty of adding the tensioner)? In other words, all things being equal, is there anything that makes a dedicated FS-SS frame better for SS than conversion a non-SS frame?
    I'm aware that a tensioner that pulls down can cause less of the chain to wrap around the rear cog, but this can be avoided by using a tensioner that pushes up.
    What I'm really curious about is whether or not there is some negative performance issues while pedaling under suspension load on a non-SS frame using a tensioner. I can't figure this out.
    TIA
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    WillWorkForTrail
    Jun 2012
    Without getting (too) technical:
    My biggest concern would be dealing with anti-squat properties and the like. Most suspension designs are made to pedal well (not bob, etc) within a range of certain gears with regards to the angle of chain pull from the front ring to the rear - not referring to lateral deflection, as us SS'ers know the importance of chainline, but rather the vertical angle of the chain between the front ring and the rear cog. Do your homework to make sure you're in the ballpark for your given frame, and I wouldn't think you'd suffer too much ill effect, although I'd still want to be able to lock the rear out when I have to stand up and hammer.
    Oct 2015
    Quote Originally Posted by Cotharyus View Post
    Thanks for your response.
    Just to make sure I understand you correctly, you're saying that I should be looking for a frame designed to have minimal chain growth over the rear suspension's travel, right? How do I find this out??
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
    WillWorkForTrail
    Jun 2012
    Quote Originally Posted by buell View Post
    Nope, way off. On the contrary, if you're using a tensioner, and you set everything up right, who cares about chain growth. I'm talking about pedal bob in the suspension.
    Maybe read this:
    Linkage Kinematics Basics of Anti-Squat and Pedal Kickback
    It talks a little about gearing in relation to anti-squat.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Chainring size affects pedal bob, because it has a direct effect on the tension of the top of the chain. If there is chain growth, a smaller chainring resists it more. For example if you were to compare 44/22 and 32/16, the gear ratio is the same but the latter combination will resist pedal bob more.
    Cog size can also affect how the rear suspension linkage works, because the side view angle is different. However, to achieve the same gear ratio a larger cog would require a larger chainring also, so the difference here is not that big.
    I think regular (geared) frames are more advanced so a SS conversion would result in an overall better bike.
    Oct 2015
    Quote Originally Posted by Saul Lumikko View Post
    I just want to make sure that I understand you correctly. Are you saying that a smaller chainring increases pedal bob? Also, that a smaller cog increases pedal bob?
    Thanks.
    Edit: I just read the article that Cotharyus linked and it makes sense now. I got the answer I was looking for. Thank you!
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
    Oct 2012
    A smaller chainring resists pedal bob better than a larger one.
    Cogs have little if anything to do with it. It's primarily about the chainring size.
    Jan 2009
    What about the Spec. Epic as a SS?
    Oct 2015
    Quote Originally Posted by rushman3 View Post
    I don't understand your question. Could you reword it?
    2003 Kona A
    2005 Kona A
    2016 Salsa Deadwood
    Jan 2009
    Redo: What about the Specialized Epic FS 29er as a Single Speed conversion?
  1. Is a 27.5+ conversion as good as a purpose built +sized bike?
    By Crankarm in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 11-10-2015, 06:05 AM
  2. Would you buy a purpose built 1x10 wide range drivetrain?
    By circlesuponcircles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2014, 06:49 PM
  3. Replies: 1
    Last Post: 07-17-2012, 12:56 AM
  4. Purpose Built Mule
    By Duntov1967 in forum General Discussion
    Last Post: 01-21-2012, 05:38 PM
  5. Purpose built shredders.
    By SuspectDevice in forum 27.5
    Last Post: 05-08-2011, 08:08 PM
