Front tire off center- Mtbr.com
Results 1 to 18 of 18
    Reputation: Houndog45's Avatar
    Oct 2010
    Off center about 1/4" ...Anyone ever seen this?
    Any ideas on what to do?
    Wheel is brand new Alex DP20...
    All I can think is, poorly dished wheel...or axle spacing off.. bummer
    one chain loop
    Reputation: fishcreek's Avatar
    remove the wheel and install it backwards.
    if it is off center on the other side then redish the wheel no prob.
    if it is off center on the same side again, then it is your fork. not fun.
    everything sucks but my vacuum cleaner.
    Oct 2010
    Ok thanks....
    Oct 2010
    Just put wheel on backwards,off center the same way..
    It's a new Surly fork BTW...
    I'm gonna go do some measuring on front fork now...
    Thanks for the quick replies!
    Oct 2010
    Nothing out of whack on fork, I'm thinking wheel needs to be redished...
    I have no Idea how to redish a wheel...
    Yikes, any way to return the wheel!!
    Or you will have to learn these skills. And buy some tools
    Park Tool Co. ParkTool Blog
    Oct 2010
    Return is not an option...
    No way I'm gonna try to redish on my own...
    I'm gonna take it to a bike mechanic...
    nothing to see here
    Reputation: Stevob's Avatar
    but you said it's off centre to the same side, so if you took a photo with the wheel mounted backwards, would that photo and the one above look the same?
    I see hills.
    I want to climb them.
    Oct 2010
    Quote Originally Posted by Stevob View Post
    Pic would look the same...
    one chain loop
    Then your wheel is fine. Do you have any other fork to do the same test?
    Oct 2010
    Quote Originally Posted by fishcreek View Post
    Yeah I have another bike I can put it on..Going back out to garage now.......
    Reputation: jtrops's Avatar
    Quote Originally Posted by Houndog45 View Post
    OK Looks like it is the fork,centers up good on other bike...
    WTF? How in the hell does a company build a fork out of whack?
    Guess I'll be contacting Surly tomorrow...
    It's not that common, but it's not unheard of either. If the fork end is brazed on just a little off, it could end up being a quarter inch at the rim.
    Oct 2010
    one chain loop
    if the legs are fine, straight, balanced and no dents, it can be as simple as burr in one of the dropuout or accumulated paint. or a manufacturing defect.
    Oct 2010
    Once again, thanks for the help !
    one chain loop
    hey no problem, nothing else to do here. i wish its warm enough here to work in the garage. winter sucks.
    Oct 2010
    Hang a blanket on the door and get a heater..
    I'm gonna take it to work,I work in a fab shop with some way craftier guys than I..
    I feel stupid now..I didn't think about dropouts being slightly off causing it to be
    a 1/4" or so out at top.....I know these things
  1. Front Center - What's the smallest?
    By pvd in forum Frame Building
    Last Post: 12-28-2009, 08:56 AM
  2. Front Wheel Off Center
    By aztec1993 in forum Wheels and Tires
    Last Post: 01-16-2009, 10:16 PM
  3. Front Center ???
    By Ottoreni in forum Frame Building
    Last Post: 07-11-2008, 12:26 AM
  4. Replies: 21
    Last Post: 06-27-2007, 11:27 AM
  5. RFX Front Center length?
    By SinglePivot in forum Turner
    Last Post: 11-15-2006, 09:06 PM
