Freewheel question.........- Mtbr.com
Results 1 to 7 of 7
    Reputation: FrontRanger's Avatar
    I am having problems with a freewheel I salvaged from a friend's bmx. I have a standard 32 tooth chainring and a 9sp chain and the problem is that the chain does not sit on the freewheel properly. It is as if the tooth spacing on the bmx freewheel is slightly wider than the chainring. I thought that I could pretty much use any bmx freeweel but obviously this isn't working. Any thoughts? Do I need a specific type of freewheel?
    bon vivant
    Quote Originally Posted by FrontRanger
    the tooth spacing is the same, but your chain is too narrow for the BMX fw. get a 1/4 inch chain or a 9spd compatible freewheel.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by truman
    That would be a 1/8" chain. Derailleur chains are 3/32" wide (or narrower).
    mtbtires.com
    Thanks for the info guys. Picked up a 1/8" chain and all is good. There does seem to be some play on the front chainring but this is obviously due to it being narrow for a 3/32" chain. Will this be a problem? I assume once I get a dedicated SS chainring it will be thicker.
    Dec 1998
    No worries. A wider chain on narrow rings/cogs works just fine.
    mtbtires.com
    'r you some kinda ssissy?
    Reputation: ssissy's Avatar
    chainging width
    the dedicated ss chainring wont be any wider unless you use bmx chainring and cranks. you migh condider sticking with 3/32 compatable parts as much as possible. when the freewheel and chain die use a 3/32 chain and freewheel.
    Quote Originally Posted by ssissy
    Makes sense. Now I just need to find a freewheel that specifies 3/32". None that I have found seem to specify one way or the other. Thanks for all the help guys. Build pics to follow shortly.
  1. ENO freewheel tool question
    By SandmanLJS in forum Singlespeed
    Last Post: 10-31-2004, 07:16 PM
  2. eno freewheel question
    By sissr in forum Singlespeed
    Last Post: 09-20-2004, 06:50 AM
  3. Freewheel Help Needed
    By lanpope in forum Singlespeed
    Last Post: 05-09-2004, 06:32 PM
  4. Rough freewheel (I think) question...
    By DSR in forum Singlespeed
    Last Post: 01-29-2004, 08:40 PM
