Freewheel Lubrication- Mtbr.com
Results 1 to 16 of 16
    Jan 2018
    My freewheel on my bike is very loud. If I were to coast down a hill with my feet off the pedals, they would eventually begin to spin forward. Can I use regular Parktool chain lube to lubricate it?
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    some freewheels are just loud
    freewheels need a special light grease or medium weight oil
    depends on make/model/version if you need something more specific
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Jan 2018
    I know lubricating it makes it quieter. What kind of lube can I use>
    What hub?
    Jan 2018
    Its a flip-flop hub with a 15T freewheel.
    Reputation: WHALENARD's Avatar
    Feb 2010
    I would use plain ole oil over chain lube.
    As far freehub lube goes dumonde tech is the best I've used.
    It is no measure of health to be well adjusted to a profoundly sick society.
    Jan 2018
    Quote Originally Posted by WHALENARD View Post
    Plain oil as in motor oil?
    Jan 2009
    no. never use motor oil on your bicycle that's silly.
    Triflow is great for stuff like this.
    Feb 2010
    Quote Originally Posted by maximusaxe View Post
    I wouldn't use any lube that contains solvents or waxes, teflon, etc. for a freehub.
    Dumonde Tech would be my choice, after a very good cleaning and inspection.
    Jan 2018
    Tri-flow is formulated with teflon(PTFE) I think I'll just go with Dumonde Tech. Thanks guys
    Jan 2009
    do you have the correct tool to remove that freewheel? definitely don't lube it with it still on your hub.
    Jan 2018
    Quote Originally Posted by mack_turtle View Post
    I've seen people just squirt it into the seam where the inner ring doesn't spin. Is it an issue if I don't remove it?
    Jan 2009
    go read my comments in your other, identical thread: http://forums.mtbr.com/general-discu...l#post13540064
    Jan 2018
    Thanks. Sorry for making you go back and forth through two of the same thread
    exactly... it's a cheap freewheel people are digging way too deep on this. when i rocked acs freewheels i'd dump whatever chainlube i had in there. all goo (some maybe imperceptably better but who really cares). any oil is much better than no oil.
    eno frewheels have a cartridge bearing so you just replace it. don't slop up the nice freewheel with oil.
  1. Is this the future of drivetrain lubrication?
    By PerthMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2013, 07:42 AM
  2. Fork stanchion lubrication?
    By Ulairi in forum Shocks and Suspension
    Last Post: 07-05-2012, 01:41 PM
  3. Shifter cable lubrication?
    By abelsfc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-29-2012, 03:53 PM
  4. Lemon Pledge and chain lubrication(dumb question)
    By chunky1x in forum Beginner's Corner
    Last Post: 02-13-2012, 05:40 PM
  5. Lubrication
    By xdeity in forum Shocks and Suspension
    Last Post: 03-31-2011, 08:14 PM
