Frankenbike hits a roadblock- Mtbr.com
Results 1 to 16 of 16
    I ordered a Gusset 18t steel cog along with a Sette tensioner (non-spring type) from Pricepoint with the hope of using my existing Shimano 32t middle ring and 8-speed chain for now to keep costs down.
    When I attempted to put it together I found that neither my 8 or 9 speed chains would seat in the cog properly. I double checked the cogs bag label and shipping statement and both said it was 3/32 which Pricepoint says works with all 8/9 speed chains.
    Apparently mislabeled at the factory (Gusset makes BMX stuff too) but it's a perfect fit for the SRAM 1/8" chain on my old steel road fixie (pre-hipster). So, do I just go 1/8 or try to get Pricepoint to ship me the right one (24 hours since I emailed them). Will the Blackspire 32t ring I was thinking of ordering work with a 1/8 chain? I know that 1/8" is stronger but again I was trying to keep things simple (read cheap) for now.
    Out spokin'
    Dec 1999
    Do as you wish but 1/8" chain is not stronger. Many (most?) us on this forum employ 3/32" multi-speed chains.
    Good luck getting your situation sorted out.
    --Sparty
    disciplesofdirt.org
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    --Sparty
    I would be using a 1/8 chain but It is difficult for me to find a 1/8 chainring and I dont find 3/32 chainrings to play well with a 1/8 chain. and I know that 1/8 chains are not stronger and a have more mass than a 3/32 chain
    "If women don't find handsome , they should at least find you handy."-Red Green
    Thanks guys, I wondered about potential problems with a 3/32 chain ring-1/8 chain combo. Taking a lot longer to get this thing up and running than I had hoped.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    You'll be fine with the 1/8th. I use 3/32nd, but they will work. Finding a replacement cob at the LBS that is appropriate size would be an easy set up.
    LBS is actually a great place but they don't have much in the way of single speed parts but could probably order just about anything. I'm about to pull the trigger on a Surly 1X1 rigid fork from Universal Cycles and they have a 3/32 cog for under $5 so I will probably go that route and hope to work something out with Pricepoint.
    In that case, make sure to spend a hundred dollars and use the VIP10 for 10% off.
    Reputation: farrisw1's Avatar
    Been runnin a 1/8 chain on 3/32 ring & cog for the last yr & a half with no problems @ all....and actually I couldn't get an 8 spd chain to work correctly on my 1x1 with the ratio I'm running for some reason, it was either too long or too short....
    Mtbr Forum Sponsor - Homebrewed Components
    Quote Originally Posted by nuck_chorris
    Then you're not looking in the right places!
    I am on the fence with the 1/8" VS 3/32" thing.
    1/8" is not stronger, but at the same time you get 30% more wear surface, so the rings and cogs tend to last longer if you use 1/8" rings and cogs.
    Quote Originally Posted by ISuckAtRiding
    yes if I did go with your custom rings then It could be great but Im on a budget so....
    right now my 3/32 chain is squeaking because I don't lube it up every time I ride
    my aluminum rings are about the same price as any other SS ring
    how much are the steel ones
    Nuck! A little research, dawg! ~50 for steel. Should last you quite a bit and are invaluable for e-riding.
    Quote Originally Posted by umarth
    Ive seen the prices before but I forgot , thankfully I have drones like you to tell me
    Quote Originally Posted by robc in wi
    There must have been a run of mislabeled Gusset cogs then because I had the same issue with the 12T, 14T & 16T I bought no more than 2 weeks ago. Actually the 7/8 spd chain that was on the bike worked sort of -- just a bit of too much 'capture' by the teeth though. Didn't think that was a good thing so switched to a 1/8" chain. Which just coincidentally enough was mated to a 36T Blackspire chainring. Didn't seem to have any problems with the mismatch but I only put ~50 on-road miles on that combo before switching to my 16T IGH & 40T cheapo chainring, both 3/32 but I'm still using the 1/8" chain. No issues so far but I've only put about 60 on-road miles on this combo. I think I'll switch to a 3/32 chain though since there's a possibility that the slight 'slop' of the 1/8" chain may actually accelerate wear.
    Good luck with your build.
    Hmm, more less than perfect Gusset cogs. At least now I know I'm not losing my mind. No replies to 2 emails to Pricepoint, I'll have to give them a call later today I guess.
