Results 1 to 5 of 5
    Reputation: 24601's Avatar
    Frame spacing? Are all the same now?
    This may seem like a stupid question to some, but in light of my recent issue with discovering my old bike I was restoring had a narrower spacing than modern bikes, this came up. I noticed that when you see frames on websites or even ebay they never seem to list rear spacing. Everything else is listed usually, but not always. I also noticed a lot of "single speed hubs" so not list their width either. For example, I was looking at some White Industries stuff last night and it says that it puts the cogs in the right place for current single speeds, but I don't know what the right space is. Are these 135mm hubs with the screw on part scooted over? I guess I am just a moron.
    I have been looking at these Fetish frames on ebay, a single speed model for $149. Has horizontal drops and what not. Also has disk mounts, but they aren't slotted so I don't know how well that might work. I know I could buy the frame then measure myself, btu what if say I was buying a Zion frame from jensen with a bunch of other components?
    I guess the assume if you have to ask this type of question then you probably wouldn't be buying the frame.
    Whatever! Just crash it!
    Reputation: Objectionable Material's Avatar
    Sep 2004
    The standard for hartail frames these days is 135mm. Some big hit and DH bikes are going to 145 or 160mm for strength. I believe road bikes have settled out at 130mm.
    Hopefully that helps a little.
    Peter
    If a man talks dirty to a woman, it's sexual harassment. If a woman talks dirty to a man, it's $3.95 per minute.
    Bike Wrench Blog ** Unfortunate Series of Events
    Shamelessly lifted from the inexhaustible font of knowledge that is SheldonBrown.com
    91 mm Low-end front hubs.
    96 mm Older front hubs, especially French.
    100 mm Modern front hubs.
    110 mm Rear track and other single-speed hubs.
    120 mm Rear 5-speed, Ultra 6, newer track hubs.
    126 mm Rear 6- and 7-speed (road).
    130 mm Rear 7-speed (MTB) and 8- 9- and 10-speed (road).
    135 mm Rear 7- 8- and 9-speed (MTB)
    140 mm Rear tandem.
    145 mm Rear tandem (newer models.)
    160 mm Rear tandem (new Santana proposed standard.)
    I should add that almost all singlespeed hubs designed for mountain biking are 135mm spacing.
    Sam
    I have seen that list, although it is not entirely accurate and doesn't really answer my question. My Peugeot MTB was a 7 speed and has 126mm rear spacing which I spread to fit a 135mm hub into.
    So, would you assume that most if not all MTB frames, single speed or otherwise, are going to be 135mm? Like that one on ebay, I should assume 135? Are there any notable exceptions? Why don't they list this sort of spec?
    kung food
    Reputation: jace's Avatar
    Sep 2004
    Quote Originally Posted by 24601
    They don't list the spacing because for 99.5% of the time, a mtb frame will be 135mm. The remaining half % will say so. The only notable exceptions I can think of off-hand is the Redline Monocog, it's 110...you can also find some other large 26" bmx-style cruiser/jump frames with 110mm if you look hard., but it's very unlikely.
  1. Bought a frame with a crack
    By MegaVolt in forum General Discussion
    Last Post: 06-18-2009, 11:51 AM
  2. What did my 88 Fat Chance sell for new?
    By mojo in forum Vintage, Retro, Classic
    Last Post: 06-20-2005, 02:26 PM
  3. comparison of ProPedal, Float and ALPS on same frame
    By ccm in forum Shocks and Suspension
    Last Post: 06-15-2004, 08:37 AM
  4. Narrow rear spacing on old Cruiser frame
    By nmcculloch in forum Singlespeed
    Last Post: 04-28-2004, 10:01 AM
  5. more mistaken 4-bar analysis
    By derby in forum Bike and Frame discussion
    Last Post: 03-11-2004, 05:20 PM
