Frame material? Steel the best? Need a bit of advice....- Mtbr.com
Results 1 to 3 of 3
    Strongbow or Bust!!!!
    Reputation: The Tractor's Avatar
    Ok, I am planning a very custom frame and I have been leaning towards steel as the primary frame material (specifically 4130). Certain parts will be 6061-T6 as well. Is this the lightest material for longevity and low cost? I plan to use the bike more for pavement and smooth trails, and it will be an idea platform as well. Any suggestions? I can provide some details of the frame if needed.
    Rob
    Fermented Apple Juice rules!!!!!! BURRRRPP!!
    Reputation: Johnny Chicken Bones's Avatar
    I'm thinking pavement and smooth trails make for good aluminum terrain. Course this might mean you are using it as a commuter, this means licking it up which means easily dented frames.
    If you are thinking super custom- find the custom steel hardtail dude in your area and have 'em make up some simple steel rig w/ a killer paint job. Add trick disc brakes and Boone cogs and your in the club.
    --------- __o
    ------- _`\<,_
    Running is for prey.
    Lemme re-phrase it........
    The bike will be an all-around bike, but very different (it will also qualify as a franken-bike). I found a source for aircraft grade 4130 in many different shapes so I'm going steel. I will be using a Pugsley fork as well so steel all around should be nice.
    Rob
