Fox Terralogic upgrade - the definitive answer.- Mtbr.com
Results 1 to 19 of 19
    Jackass
    This was some discussion a while back if a regular Float Forx
    could be upgraded to Terralogic. The answer is..... (drum-roll,
    please)..... yes.
    I ordered the damper from Fox ($158, shipped) and put it in
    my Float RLC. Direct swap with the old damper. No muss,
    no fuss, took about 15 minutes, works great.
    The only caveat - my Float... excuse me, f100x , is a
    100mm... YMMV with 80mm stuff.
    Remember folks, you heard it here first.
    ZB
    No hairSShirts.
    Pivoteer
    Reputation: tiSS'er's Avatar
    Tell me more!!!!
    Do you have the part numbers fro the parts you ordered? I contacted fox on several occasions and they told me it was not possible. Do you have an RL or RLC?
    What if I only want my 100mm fork to be an 80mm fork?
    Thanks,
    Brandon
    Yes indeedy.
    The float can indeed be converted to 80. Did You buy the fork in a box? If You did there should have been a small plastic piece in the box. It is all You need to convert it. (It is much easier than the directions' make it look)
    Recovering Weight Weenie
    Reputation: Padre's Avatar
    Quote Originally Posted by gearless
    What if my wife has a regular Fox Float 100 R... can it too be converted?
    Hugh is all smiles and giggles tonight after converting his 80mm RLC to the terralogic....he LOVES it...
    Mashers Only!!
    Reputation: HUGH's Avatar
    Quote Originally Posted by Padre
    My fork was an 80RLT now an 80X. An easy swap. It does what it says. Works flawless!!!
    Erik I'll check for ya tomorrow!! What year is her fork??
    HUGH
    Jackass
    Conversion
    The Float R should convert just fine.... Is just has a couple less knobs than the
    RLC.
    I think I still have the part number lying around at work for the cartridge. I'll post
    it when I get to work if so.
    Perhaps Hugh can post the number for the cartridge he used so that we can
    tell if the 80mm damper is different than the 100mm. I think it may be. I know
    that to change a 100mm to 80, you use the 100mm damper and just put the spacer
    in the air spring side. I suspect the dedicated 80mm forks MAY have their own
    damper, though. Hugh?
    No hairSShirts.
    Jackass
    Part number
    Part number for Terralogic damper, 100mm -
    820-04-020
    $150 + shipping ($8 for me)
    You can order by phone at extension 6550
    This went into a '04 Float RLC with no problem....
    should be exactly the same for R and RL.
    TiSS'er - If you have a 100mm fork, you can use this
    damper. The plastic spacer that (should have) came
    with the fork can be installed in the air spring side to
    give you 80mm.
    Once again, so nobody gets mad at me - I know this
    will work for a 100mm fork, or a 100mm converted to
    80mm. You'll have to ask Hugh if this is the same
    part number for a dedicated 80mm fork.
    Oh, and I would suspect this voids the warranty
    Good luck.
    No hairSShirts.
    BLS439
    Reputation: BLS439's Avatar
    What about an '03 FLoat RLC 100?
    Quote Originally Posted by brewSSard
    820-04-020
    give you 80mm.
    Good luck.
    Do you know if this kit would work in the 2003 Float RLC 100? I hope so...
    --BLS439
    Quote Originally Posted by HUGH
    My fork was an 80RLT now an 80X. An easy swap. It does what it says. Works flawless!!! Erik I'll check for ya tomorrow!! What year is her fork??
    HUGH
    Leslie's is the first year they came out. i thnk the internals are different than yours..
    Mashers Only!!
    The part number is
    820-04-019 Fork sub group:Cartridge, 03 f80x
    HUGH
    Reputation: Soupboy's Avatar
    OK, but can you do it with a TALAS?
    ...are you swapping the guts of the right or left leg? Guessing right, not sure why.
    Sean
    Professional Amateur
    ali'i hua
    Reputation: SlowSSer's Avatar
    HUGH
    dude- you couldnt say enough good about this upgrade last night. that's how the luge was- one long rave from hugh about his fork.
    WAWE
    Quote Originally Posted by Soupboy
    woooo
    I'm also dreaming of a TerralogALAS... !
    The race, not the animal!
    Reputation: sea otter's Avatar
    I have an 80RLT - I hope this is not a stupid question
    but on my 100X I do not have a lock-out on the right hand fork upper. Does the cartridge for the 03, f80X replace the lock-out or you just leave it on and not utilize it?
    Do the one thing you think you cannot do. Fail at it. Try again. Do better the second time. The only people who never tumble are those who never mount a Single Speed!. This is your moment. Ride On !!!
    Mashers Only!!
    Quote Originally Posted by sea otter
    It replaces it.
    HUGH
    Pivoteer
    Thanks, ordered mine today
    Thanks brewSSard for your help, after several emails and a few phone calls, Fox cleared everything up for me. I called them about a month ago and they said it wasn't possible. After badgering today they finally got me everything I needed and I will see it Friday, just in time for the weekend.
    Thanks for everything, Fox stuff is $100 less than the Stratos kit, which I still have not yet received, cancelled my order today.
    Thanks again, I will let you know how it goes after this weekends rides.
    Sorry, I'm a bit slow. The wife has an 02 Fox Float R.
    Can this puppy get the switch or is it too old?
    Mashers Only!!
    onefitty and you are good to go man!!
    HUGH
    Wow that's awesome! I didn't even knew that upgrade existed! That is so awesome, certainly contemplating it for my '04 Stumpjumper.
  1. Replies: 9
    Last Post: 03-28-2005, 07:42 PM
  2. 02 Fox Float R- Leaks Air, Need upgrade or fix ideas?
    By jhc in forum Shocks and Suspension
    Last Post: 03-10-2004, 08:31 AM
  3. Push upgrade on a Fox Vanilla RC w/remote lockout?
    By MondoRides in forum Shocks and Suspension
    Last Post: 03-03-2004, 06:42 PM
