flip/flop hubs & dropout length?- Mtbr.com
Results 1 to 6 of 6
    Reputation: TrevorInSoCal's Avatar
    Question for those of you running flip-flop hubs.
    How much variance in gearing can you get away with and still have enough room for adjustment in the dropouts w/o having to adjust the chain length?
    I've been commuting to work on my fixed-gear road bike geared 42x16. Problem is I do a Wednesday night mtn. bike ride that I can't make it to on time if I commute on the bike. I really hate to miss out on my wid-week dirt fix, but I hate driving to work if I don't have to. If I commuted on my ss mountain bike I could probably make it to the trailhead by the time he ride started, if I had a taller gear. I don't relish the idea of doing my 15 mi. road commute (+ an extra 5 after work to get to the ride start) on a SS geared for off-road riding. I'm considering building up a wheel with a flip flop hub that I could install a smaller fixed cog on and then just flip it over when I got to the trailhead, but I'm not sure that'd work.
    Question is can I get anywhere near an equivalent gear-inch to 42x16 w/ a 34t front ring and still have enough adjustment to flip it over and run 34x17 w/o adding/removing links in the chain?
    -Trevor
    Reputation: pacman's Avatar
    A 34x13 would be equivalent to your 42x16. If you want to also use a 34x17 then you need one-half inch of adjustability in your dropouts between the two positions. In other words from your current 34x17 position you need 1/2 inch of extra length for a 34x13 to work.
    not likely...
    Quote Originally Posted by pacman
    The axle is just past the midpoint now. Looks like there's probably not enough room to tension the smaller cog.
    If I could remove a link and still fit the 17t in there, w/o bottoming out on the droput, it might work.
    The other thing I hadn't thought about was pedal-strike. I'd hafta be real careful on corners riding fixed w/ 180mm cranks.
    Thanks for the info.
    -Trevor
    Reputation: brant's Avatar
    take a full link out and throw a half-link in there and things might be easier
    Measure twice - cut once
    Removing one link moves the axle forward 1/2 inch, adding a half-link moves it back 1/4 inch.
    (with a few mils of precision)
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    I did something very similar on my Crosscheck. I was using 42x16 (fixie) to ride around town, but I wanted to play on the dirt as well. With a 20T, I need to add one link, and it's really easy with a spare link and Powerlink. The wheel ends up in practically the same place.
  1. Crank arm length, and benifits of.
    By The Tree in forum Downhill - Freeride
    Last Post: 08-02-2012, 08:06 PM
  2. WTB Laserdisc lite hubs
    By Earthpig in forum Wheels and Tires
    Last Post: 05-16-2004, 10:03 PM
  3. Paging Trevor with the blue King hubs
    By MoonriseRascal in forum Weight Weenies
    Last Post: 02-27-2004, 09:52 AM
  4. cone wrenche size for Shimano hubs
    By PBK in forum Tooltime
    Last Post: 02-17-2004, 01:44 PM
  5. American Classic/WTB disc hubs
    By GrantB in forum Wheels and Tires
    Last Post: 01-19-2004, 08:44 AM
