Flat or Riser? Bar ends or no bar ends?- Mtbr.com
Results 1 to 16 of 16
    Hi Everyone,
    Just recently converted my Santa Cruz Chameleon to a single speed, and I had a few questions about handlebars. I was contemplating getting risers rather than a straight w/ barends (which is what I have now). The bar ends help during my climbing (standing up and using them as leverage), but I think I pulled a muscle in my forearm - probably my grip is to tight/bad form. So, I was going to go to risers with no bar ends, and maybe a longer stem to get better leverage when standing.
    What do you guys think? Any school of thought on which way to go?
    Thanks,
    mm
    Out spokin'
    Dec 1999
    Personal choice
    Personally, I use flat bars with bar ends. But risers are currently in vogue.
    --Sparty
    disciplesofdirt.org
    formerly Giantxc
    Reputation: MrXC's Avatar
    Flat or riser, go with bar ends. I'm really amazed more SS'ers don't use them - climbing out of the saddle just feels so much more natural than on the handlebar.
    I'm thinking drop bar or maybe new on-one moustache for my 29er SS which is in the pipeline. I definitely agree "side on" (for want of a better description), gives you a much stronger position to pull from than straight on a flat bar - which would seem to be essential for singlespeeding..
    Sam
    Reputation: ATXSS's Avatar
    Salsa Moto-Flat bars...
    --Sparty
    Did you leave those 26" with the bar ends? I have bee using the same bars because of the 11 degree sweep that they make them with, and I've been considering bar ends. I'm just not sure about adding them to a bar that wide, and also the big sweep would end up flaring the ends outward (my barend choice would be the cane creeks) and I'm not so sure about how that would feel. Are yours the 11 degree or the shallower bend?
    Reputation: ernesto_from_Wisconsin's Avatar
    fruit
    Quote Originally Posted by Kolo
    Sam
    Fron now on, I am going to swap my bars for a mango and some toast. The mango will help me in the technical sections, while the toast will help on climbs and right turns. I am also going to get an eccentric bottom chainstay that hooks up to a 4" suspension brake lever.
    Reputation: scottms33's Avatar
    riser
    i am using a 1.25" riser and its a bit wider than normal, i used bar ends for a few years but took them off one time and didnt miss them so havent put them back on
    scott
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by martinman
    Hi Everyone,
    Thanks,
    mm
    DROPBARS!
    But I always say that.
    mtbtires.com
    Reputation: Zen_Dude's Avatar
    I like riser bars, I have a chameleon with 90mm 5 degree rise stem and Easton risers.
    Works for me, not so bent over, easy on the back
    What the....?
    Quote Originally Posted by ernesto_from_Wisconsin
    Man you lost me....
    Man you lost me....
    I was being silly. I need to tension up some slack with the eccentric top tube. Just slack. No chian needed. I also want to get a linear pull saddle, A Horst Link set of spokes, and a Ringlé WHachamajinger.
    Out spokin'
    Dec 1999
    Quote Originally Posted by ATXSS
    My S.a.l.s.a.s are like 3 or 5 degree sweep. They're uncut. I've got some T.i.t.e.c Hellbent bars that are close to the same width as the S.a.l.s.a.s (12 degree sweep I think?) and they feel way different... I guess I'm so used to near straight bars that I've grown to like them better (in spite of the fact that bars with more sweep are supposed to be more ergonomic).
    Anyway, I have no problem with wide bars and bar ends. As you can see, mine are "L-bends" so they feature incorporated anti-tree-grab/knuckle-protection devices. These have proved invaluable over the years... The wider my handlebars, they more the bar ends like to hook saplings...
    --Sparty
    disciplesofdirt.org
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    re: bar choices
    Quote Originally Posted by Zen_Dude
    I know this is like arguing whether there is life on other planets, but FWIW, I use a long 120mm chromo Titec stem and an old titec hellbent riser (yellow of course) I love the length on the SS (my dually I use an 80mm) and the risers is as wide as I prefer to use, gives good leverage and strength transfer when coupled with the stem. With this combo I have never really needed barends anywho. The bar ends scare me with the up-downs that the trails I ride have. The concept of being on the barends on an up only to drop into a chute all rigid and bouncy is a little scary. Or is it just me?
    MTBR Posting Guidelines
    calories>electrons
    Ebo
    Ebo is offline
    I run the Salsa Pro Moto's also. Kept them at 26" and they have 5 degrees of sweep. Titec Shorty bar ends as well.
    How about some Jeff Jones H-bars?
    TR
    TR is offline
    Angry bunny
    Reputation: TR's Avatar
    Ernesto
    You should try a double clamp hub, Stan's No (Seat) tubes and Oury lock on stem caps. They may be just what you need.
    Ummm..............errr.............I mean to say you are a very silly man.
    Oh yeah. And a vote for risers as well.
  1. Carbon flat bar that can take bar ends?
    By bsavery in forum Weight Weenies
    Last Post: 06-21-2004, 10:04 AM
  2. Flat bar compatible with bar ends
    By -kelly- in forum General Discussion
    Last Post: 04-15-2004, 10:10 PM
  3. Bar Ends -or- No Bar Ends
    By htims_nivek in forum Riding Passion
    Last Post: 03-22-2004, 10:15 AM
  4. Flat bar vs. riser
    By kepi in forum General Discussion
    Last Post: 03-09-2004, 12:25 PM
  5. Flat bar vs. riser
    By kepi in forum Beginner's Corner
    Last Post: 03-09-2004, 07:56 AM
