Results 1 to 14 of 14
    Cars Are Evil
    Reputation: Vermont29er's Avatar
    Fixed rear hub that uses casette cogs?
    I want to try fixed for a while. I'd like to be able to use the singlespeed casette cogs I already have, so I can adjust. Does anybody make a hub that's fixed and uses casette cogs?
    DiscoCowboy
    Reputation: Allroy's Avatar
    Not that I know of
    Best/Easiest bet is to pick up a TomiCog take off your disk rotor and bolt it on (assuming you have a disk hub) flip your wheel around and ride. Other option is depending on what kind of cog you have you can drill your own.
    https://classifieds.mtbr.com/showpro...t=15071&cat=24
    Whatever you end up with it's fun... hard but fun.
    Quote Originally Posted by Vermont29er
    What about just going for a Surly fixer and a cheap cog. That way you don't have to rethread the wheel.
    http://www.surlybikes.com/parts/fixxer_pop.html
    is buachail foighneach me
    Reputation: sean salach's Avatar
    http://www.midwestbiketrials.com/sto...roducts_id=146
    alot of ss/multispeed stock bikes use front freewheels and fixed rear hubs. this is not the only option:
    Nope, no one makes one. I think it'd be a good idea, but the body would have to be made out of some tough stuff. You can try fixing your own freehub body. I've seen one that has screws drilled and tapped to prevent it from turning for a cheap fixed gear conversion.
    you sure about that schmucker?
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    A.M.Y. hinted about a splined fixie/free hub from White Industries in this thread. Show us the goods, A.M.Y.!
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    DiscoCowboy
    The Echo fixed cog
    is still proprietary to the hubs isn't it? You couldn't take say a Surly cog and slap it onto the Echo hub correct?
    Quote Originally Posted by sean salach
    I wanted to try fixed gear, so I took the freehub body off my Shimano hub, then welded all around the back of it. If you've looked at the back of a freehub before, you know the gap where the inner part and outer part off the freehub meet and you can see all the tiny bearings inside it? Yeah, I was welded that solid. It worked very well, but I didn't have much fun so the modified freehub came back off and go thrown in the parts bin.
    Reputation: Dekes's Avatar
    g
    Quote Originally Posted by Schmucker
    Wrong
    Try-all and Viz have fixed 6 speed cassette hubs.
    Reputation: Nater's Avatar
    They use a proprietary cog mounting system (not Shimano splined cogs) but they look really nice...Level Components.
    Reputation: AteMrYeats's Avatar
    The wheel is no longer in my possession. I wasn't able to get the chainline close enough. Here's what the interface looks like:
    Those mountain bikes that yet / Fresh mountain bikes beget
    the viz looks like a pretty standard spline interface to me, but i've never used one:
