fixed monocog?- Mtbr.com
Results 1 to 6 of 6
Thread: fixed monocog?
    fixed monocog?
    I was thinking the other day about trying out fixed gear in the city, and went down to my lbs and tried out a specialized langster set up as a fixie, and, well, it could take some getting used to, but all in all, i liked it and came up with this crazy idea. I would like to build up a monocog as a fixed gear with a front brake....but theres a catch. Since the bike will see limited dirt, i was thinking about running 700c wheels with cyclocross tires and maybe a emergency brake on the front.(disc probably). Is this a bad idea? Any other suggestions for a similar build?
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    It well work but.....
    A 700c wheel well not line up the brake posts on the stock fork or the rear brake posts. So you would need a disk fork or a surly crosscheck fork or somthing like that.
    cause it's fun
    If you have a newer MonoCog then you have the ability to ad disk brakes, and should have no problem.
    bus driver wanna be
    Reputation: henrymiller's Avatar
    Quote Originally Posted by dompedro3
    I have been running my first generation MonoCog fixed for about 3 months. So far no problems. Never looked into the 700c wheels, but with the stock wheels and slick tires I do fine. I run 38x16 and am about to change to 44x16. If you use stock wheels you will need to run a front brake, since there are no threads for a lock ring. No lock ring + no front brake = bad
    Roscoe's Chicken 'n Waffles
    Jan 2005
    Paul Comp may help
    Quote Originally Posted by SlowerThenSnot
    I wondered about running cross (700c) wheels on my mtb and came up with the following solution - Use a set of the BMX Motolite brakes from Paul Components, allow the brake blocks to rise to a position where the will align with 700c rims and give excellent braking power
    heres a thead from another board from somone who bought one setup that way...
    http://forum.bikemag.com/forum/showf...=&fpart=1&vc=1
    looks pretty cool! (scroll down for a pic)
  1. I got the Monkey fixed...(x-post 29")
    By sslos in forum Singlespeed
    Last Post: 09-23-2004, 05:21 PM
  2. I got my monkey fixed...
    By sslos in forum 29er Bikes
    Last Post: 09-23-2004, 05:18 PM
  3. Married to your Monocog?
    By turtlelite in forum Singlespeed
    Last Post: 04-13-2004, 08:17 AM
  4. Worth upgrading Redline Monocog?
    By SingleSpeedPA in forum Singlespeed
    Last Post: 03-22-2004, 08:16 PM
  5. disc + freewheel + fixed gear?
    By qtip in forum Singlespeed
    Last Post: 02-13-2004, 08:04 PM
