Fixed great mtb and cornering...- Mtbr.com
Results 1 to 10 of 10
    Reputation: DualRollers's Avatar
    Apr 2014
    Quick question for all you fixed riders: how do you handle cornering? I ran fixed on my fat bike for a ride, but couldn't figure out how to successfully corner with any speed at all. No matter what I tried my pedals dug in... Is this a bb height issue, or a technique thing? I would really like to figure it out because running fixed was fun as hell aside from that.
    Oct 2013
    That's part if the joy of riding fixed gear off-road. The other part would be smacking rocks, logs, and such while riding straight ahead. You could try 160 mm cranks or run a freewheel.
    Reputation: eselsweg's Avatar
    May 2010
    Quote Originally Posted by DualRollers View Post
    IMO "the fun as hell" is all that matters. I'm no super rider but I love riding SS, rigid, and FG. It seems counterintuitive to be an average Joe and raise the technical bar with FG even hirer but I like it! And that's what makes me feel like I'm just riding and not judging if I should "do this" or "do that". Ride a fixed bike, get off and push if I must or retry that tricky section. It makes me feel like I'm doing my own thing and not thinking to be something more than I am.
    When my crank digs in on a curve then it doesn't mean I need to change my gear - it's just riding.
    Moderator Moderator
    Reputation: Walt's Avatar
    Nose wheelie around all corners.
    -Walt
    SP Singletrack rocks
    running fixed gear makes you worse at corner at other non fixed geared bike.
    Reputation: paqrat's Avatar
    Learning to time / position your crank positions while cornering will definitely help.
    Are you running super low tire pressure? The deformed tire is likely eating up your pedal clearance with the ground...
    Oct 2011
    Quote Originally Posted by paqrat View Post
    _FIXED_ gear. You don't really have a choice as to your crank position when entering a corner...it is where it is.
    Which is also the answer here. It is what it is. You'll have to adjust your riding style to compensate...you'll be taking corners slower and more upright to avoid pedal strikes...which are also just going to happen. Par for the course
    Quote Originally Posted by Walt View Post
    -Walt
    Or even just wheelie. Walt is on the right track here, just think outside of the box.
    Reputation: Ruffstuff's Avatar
    Jan 2015
    When the left cranks down, turn right 😂👍
    Sent from my HTC One_M8 using Tapatalk
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Fat bikes often have low BBs and the wide Q-factor makes matters worse. Cornering when fixed is a challenge.
    As for timing the cranks, you can do it just like you do when going over obstacles: stop the cranks and skip the rear before the corner (or obstacle) to have the cranks in a desired position when it's critical. It's hard as hell, I'm still struggling with it.
    I like fixed MTB riding, but my fat bike is and remains singlespeed (or geared sometimes).
  1. Great day, great ride, great people
    By 450VoltsDC in forum North & South Carolina
    Last Post: 02-28-2012, 02:02 PM
  2. Cornering
    By mtnbkrdr98 in forum Idaho, Montana, Wyoming
    Last Post: 12-14-2011, 08:31 AM
  3. Fixed/Fixed multi cog MTB hub
    By Mr.Bee in forum Singlespeed
    Last Post: 08-03-2011, 07:35 PM
  4. Advise on cornering?
    By esundell90 in forum Beginner's Corner
    Last Post: 07-06-2011, 10:52 PM
