Fix speed questions- Mtbr.com
Results 1 to 5 of 5
    Feb 2018
    Fix speed questions
    Have a 95ish trek 870 that I would like to convert to a single speed. Where do I start? (Dumb Question?)
    Cif
    Cif is offline
    Reputation: Cif's Avatar
    Jan 2013
    Quote Originally Posted by mkirsch View Post
    Determine what gear you need.
    This depends on the terrain you ride and how strong you are.
    If the bike is still fully functional with gears, I'd try to ride your terrain not shifting to see what's best for you.
    After that:
    Remove front & rear derrailer, chain, shifters and shiftcables.
    Then put on new cog, chainring, chain and chain tensioner.
    That should do it.
    Edit: sorry, forgot you also need a spacer set for the cog
    Sent from my ONEPLUS A3003 using Tapatalk
    Reputation: azimiut's Avatar
    Feb 2014
    like posted. find what gear you prefer. go ride your trails and don't shift. get the then get a ss speed kit with the gear ratio you need.
    Dont make me go all Jonathan Winters on this gas station.
    Hardtail Steel Forever
    Reputation: jestep's Avatar
    Quote Originally Posted by Cif View Post
    This basically sums it up. If you have a standard crankset with replacable rings, you can convert it to a single chainring.
    Wolftooth is a good place to start. They aren't the cheapest but make very high quality chainrings and SS cogs.
    There's a few options for chain tensioners. Check out reviews but most of them work well.
    WTB: Med Bontrager Ti Lite, PM Me...
    Jan 2009
    Everything you need is right at the top of the forum
    http://forums.mtbr.com/singlespeed/s...aq-780004.html
  1. Fix front derailleur / mech on carbon frame with no frame-integrated direct mount fix
    By vEHMv in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2016, 10:59 AM
  2. Sram TYPE 2 10-Speed Rear Derailleur with 9-Speed cassette + -speed Gripshift
    By jaxson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-02-2014, 09:43 AM
  3. 2 speed VS 3 speed shifter on a 2 speed crank??
    By 2000Z3M in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-18-2012, 11:46 AM
  4. Replies: 4
    Last Post: 06-16-2012, 12:39 PM
  5. Speed, speed...... more speed!!!
    By hellbeni in forum Videos and POV Cameras
    Last Post: 06-23-2011, 09:16 AM
