fisher rig and bottom bracket- Mtbr.com
Results 1 to 2 of 2
    Jan 2005
    I decided to chuck my external bearing cups on my Gary Fisher Rig because I've tired of them failing and installed a square taper bb-un52 I had laying around. Unfortunately the cranks that match (Raceface next lp) don't seem to work. The 34 tooth ring I want on there hits the chainstay and the ring isn't large enough to bolt onto the outside of the spider - it hits the crank. I don't know what the width of the bb spindle is, but I assume I need a wider one. I have no idea the current width of the bb-un52 because it's not printed on the bottom bracket. I'll measure it, but was wondering what width bb folks are running on their Rigs.
    Thanks for any help!
    -jon
    ps the bb seems to be 111 mm wide after measuring if that width exists, maybe i was a little off and it's 113.
    Sweep the leg!
    Reputation: Caffeine Powered's Avatar
    Mar 2005
    I called the Trek Factory Store (just for you!) and they are 95% sure it's a 113mm. I'd pull mine real quick for you but I didn't get an Isis tool for it yet.
