First Time SS Build Need Some Advice- Mtbr.com
Results 1 to 6 of 6
    CS2
    CS2 is offline
    Reputation: CS2's Avatar
    I picked up a nice donor bike. After I take off the group I'll be left with a frame/fork and wheels. So, I'm thinking this is a good to time to try a SS. The bike is a 1986 Rockhopper spaced 126mm in the rear. The rear hub is threaded so a BMX freewheel should go on. My question becomes what to use for a crank and BB?
    A garage full of steel frames means happiness.
    On my budget SS build I used the existing cranks and BB. I too have a threaded rear hub and am running a BMX freewheel with a 3mm spacer. on the spider, I'm running the internal ring position.
    Reputation: 2002maniac's Avatar
    Nov 2008
    Whatever you can scrounge on ebay/craigs
    CS2
    CS2 is offline
    Quote Originally Posted by Pea-Ta View Post
    That's what I was thinking. But the group less wheels is going on another vintage bike. I bought this as a donor bike. It's so nice that I figure I can do something with it other than CL or ebay it. So, that leaves me without a BB or crank.
    Ahhh ok, you could head to the lbs and see if they have some used cranks and BB laying around... Then pick up a hbc chainring.
    Look for an FSA Maximus crankset on ebay. I picked up a brand new set a couple of weeks ago for $12. No joke the seller had several sets. They came with a 22t and 32t chainrings + bash guard. Remove either chainring and voila, Singlespeed cranks. Good luck with the project.
  1. Long time rider - First time DJ'er needs some advice
    By woodyak in forum Urban/DJ/Park
    Last Post: 10-28-2011, 01:27 AM
  2. Advice on first time bike build
    By Scarney19 in forum Downhill - Freeride
    Last Post: 11-12-2008, 07:58 AM
  3. First frame-up build, need parts/build advice (long)
    By Blatant in forum General Discussion
    Last Post: 05-11-2008, 04:41 PM
  4. Replies: 30
    Last Post: 09-12-2007, 12:59 PM
  5. 9 speed advice needed for first time build
    By le0p in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-17-2006, 09:05 AM
