Finally got one: Schwinn Panther SS- Mtbr.com
Results 1 to 39 of 39
    Reputation: arcdesigns's Avatar
    Not stock but the price was right
    Now time to make my dream bike!!Finally got one: Schwinn Panther SS-image.jpgFinally got one: Schwinn Panther SS-image.jpgFinally got one: Schwinn Panther SS-image.jpgFinally got one: Schwinn Panther SS-image.jpg
    one chain loop
    Reputation: fishcreek's Avatar
    Subscribed, your build is always stunning.
    everything sucks but my vacuum cleaner.
    What suspension forks should I be looking at?
    Need: 1" Steerer
    Would like: Disc Brake tabs
    Thinking: 80mm
    Quote Originally Posted by fishcreek View Post
    Bike for the heck of it!
    Reputation: tds101's Avatar
    May 2013
    Sweet!!! I can't wait to see how this turns out,...
    Meh,...
    Reputation: vaultbrad's Avatar
    Oct 2007
    I want to watch this build too.
    Reputation: Possum Jones's Avatar
    Subd for build!
    Ride Bikes
    Drink Beer
    Weights
    Here are some actual weights:
    5 lbs on the frame and 1.5 on the fork.
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-img_6194.jpg
    Finally got one: Schwinn Panther SS-img_6177.jpg
    Here is a mock-up with a suspension fork. Once I removed the headset cups I was able to slide a suspension fork I had on hand with a 1 1/8" steerer into the head tube. This will give me an idea how it will look.
    My head set removal tool was to big so I had to fab one using an iron gas pipe. Took an hour to cut but in the end worked perfect.
    The rear disc brake adapter lines up perfectly however I was sent the 180mm and I need the 160mm.
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-img_6188.jpg
    Finally got one: Schwinn Panther SS-img_6187.jpg
    Finally got one: Schwinn Panther SS-img_6161.jpg
    Weight of the crank with ring
    598 grams
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-img_6211.jpg
    Jun 2013
    Can't wait to see it complete. Subscribed.
    fresh fish in stock...... SuperModerator
    Reputation: CHUM's Avatar
    Quote Originally Posted by arcdesigns View Post
    Need: 1" Steerer
    Thinking: 80mm
    White Bros "magic 80" i think has 1" steerers for a special order....they used to anyhow.
    look forward to your build!
    Click Here for Forum Rules
    bike rider
    Reputation: mattkock's Avatar
    I miss mine but it has a Great home in Colorado!
    King 1" headset, Avid V-brakes, Bontrager rims, Thomson post, Salsa stem, Avid Ultimate lever, Flite saddle, Cook bros. E cranks.
    My Bikes Kick Ass!!!
    Quote Originally Posted by CHUM View Post
    White Brothers will build one of their Loop suspension forks with a 1" steerer for only $30.00. Problem is the Loop has a 15mm axle!
    Quote Originally Posted by mattkock View Post
    I think it was your post here on mtbr that lite the spark of me wanting to do a build with this bike so thanks
    She was born in 1999
    If I read the chart correctly October 7th, 1999
    Finally got one: Schwinn Panther SS-photo.jpg.
    What is that rear brake adapter?
    one chain loop
    it is a u-brake.
    Quote Originally Posted by half_squid View Post
    I got it on eBay. Here is the item # 271221549088
    Thanks. Looks like a fun build.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    What's called a "Mix" headset will allow the use of the 1 1/8" steerer in the 1" headtube. Check Dan's Comp.
    one chain loop
    sorry, i didn't even notice you rear disc. how secure is it?
    No worries.
    It's the missing link. Super simple and totally effective. By far the best disc adapter I have ever encountered.
    If Paul Components had one of them 5 years ago it would have been his best seller
    Quote Originally Posted by Dirty $anchez View Post
    The one I found on danscomp.com is the opposite of what I need: "ACS Integrated 1" Conversion headset allows the use of 1" forks on a race frame with 1-1/8" integrated headtube"
    There is also one designed by one of the Coaster Brake race guys but it will not fit. I have the small headtube for 1" and the one it works on is the large headtube for 1."
    I think it said it works one the older 70's and before era cruisers.
    I was "only" just able to get my 1 1/8" forks steerer into the headtube.
    Hhhnnnngggg!!!
    Mar 2012
    I used a 1 1/8" Cane Creek threadless Aheadset on a Panther I had with no problems. I still have the full carbon 1 1/8" disc fork I used on it. It was a 2006 frame or something.
    Reputation: banditfl's Avatar
    Nov 2012
    I want one.
    Quote Originally Posted by TwigJumper View Post
    ...and there is the rub. The 06' in addition to canti bosses must also have a larger headtube. On mine a 1 1/8th steerer only just fits into the raw headtube without any headset.
    Reputation: BeginnerCycling's Avatar
    subscribing!
    Progress update: Nothing
    The 1" (and odd 1" at that) headtube is slowing things down. It's 29.3mm so I can't even put in my Chris King (needs 30.1mm) until I have it surfaced and I can't do that until I paint it The upper cup of the headset that came with the bike was swapped out by the previous owner and the one they put in is not functioning correctly.
    Plus the few 1" suspension forks that have come up are not what I had in mind. I really just wanted to put on a Fox F80 painted black and call it a day...
    ...oh I did swap out the seat with a nice Brooks Swift titanium so she now looks a bit sexier. If I end up keeping the Swift I was thinking about stripping one of those copper Schwinn badges they have on eBay to match the copper rivets on the Brooks.
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-393706162_703.jpg
    Here is a pic of the Swift.
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-schwinn-swift.jpg
    Reputation: gmmeyerIII's Avatar
    May 2012
    Do you happen to still know the seller for this adapter?
    I am not able to locate on ebay.
    Really cool build by the way!
    I found it thanks!
    Quote Originally Posted by gmmeyerIII View Post
    Incase anyone else is having problems finding the seller here is a link to his eBay page:
    eBay My World - apar9518
    Here's the way my Panther is configured...for now. I picked it up for $175 on ebay. It was one of the many used by the DNC when it was in Denver. This bike is so sweet.
    Attached Thumbnails Attached Thumbnails Finally got one: Schwinn Panther SS-img_1174.jpeg
    Quote Originally Posted by NoHg View Post
    You looked older when I saw you last
    Jun 2012
    Is there enough material on the steerer tube of the fork you want to have it turned down on a lathe and still have it be strong enough? If not, maybe you could have the steerer tube removed and replaced. More wall thickness or stronger material would keep it strong but maybe make it heavier, right?
    Reputation: rynoman03's Avatar
    Nov 2012
    Quote Originally Posted by bugshield View Post
    Good point. It'd be cool to make it a taper'd headtube then you could run whatever fork you wanted.
    Jun 2014
    You guys motivated me to rebuild my SS Schwinn Panther. I am still trying to remember what year it is, but it's alloy. I am going to add some Race Face Cranks, Easton Stem and Bars and Thomson Seat Post, Selle Saddle, and many more clearance sale parts. I will post pics with full specs soon. I admit I have been a Roadie for the past several years, but my SS Schwinn Panter reminds of many of the great mountain bikes I have had in the past like my Ritchey, Gary Fisher and Cannondale Lefty. Hopefully, this thread will come back to life.
    Oct 2014
    Anyone have an update on this?
    I am having the same issue with a weird sized head tube.
    Nov 2012
    Just found my local non-profit community cycle shop has one in the earn a bike section. I might try to see if I can buy it and convert it. Still looks like a fun project.
  1. Panther Creek, near Knoxville
    By wv_bob in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 06-06-2013, 07:14 AM
  2. Paid Spam: Schwinn Panther Klunker Frame & Carbon Fork
    By TwigJumper in forum Singlespeed
    Last Post: 04-20-2013, 06:14 PM
  3. Schwinn Panther SS!
    By mattkock in forum Singlespeed
    Last Post: 02-09-2013, 06:26 PM
  4. Yet another klunker project (1950 Schwinn Panther)
    By First Flight in forum Vintage, Retro, Classic
    Last Post: 10-09-2012, 02:22 PM
