Few teeth short of a cog- Mtbr.com
Results 1 to 6 of 6
    Reputation: happygofun's Avatar
    Hi, long time lucker first time poster.
    My local shop owner claims I should say this happened "that time I was racing a motorcycle, uphill..."
    But it wasn't that exciting and happened a little downhill from here.
    It started off as the usual headlands loop just across GG bridge.
    Nice ride though mainly fire road. The 34 tooth chain-ring on my cross-check is out of round, but it's been that since I put it on a year ago. There are loose and tight points, significant but it had been trouble free. I think I'd only lost the chain once on this setup. Bouncing down the Old Springs trail into Tennessee Valley the bike ping-ponged off rocks and was a blast.
    It's fun, the speed is limited but you get to look around and spend more time playing on the bike. Then the chain dropped. The wheel locked up and the chain back-wound itself around the 17 fixed cog. Then I heard the alternating grinding and popping sounds of the teeth shearing.
    Come to a stop finally and hop off to survey the damage. Chain really dug into the BB
    The cog was pretty cleanly broken. Hmmm.
    Flip the wheel and limp the rest of the loop home on the 20t freewheel.
    Now just waiting for the replacement cog to come in this week.
    Disclaimer(s)
    1. ss content, well two gears but had to flip the wheel to ride out.
    2. photo's not all from same ride.
    Hit The Road Cyclery
    Reputation: -Anomie-'s Avatar
    Jan 2005
    Can't say that I've ever seen that before. Is that an aluminum cog?
    not alluminum
    nor stamped steel. It's a genuine EAI forged track cog.
    Just a bad enough case of chain suck to do it in
    albert
    elbow gloves
    Reputation: kinkcrazy's Avatar
    brittle fracturing cogs
    there is an article on 63xc.com about the manufacturing process of cogs, describing how certain heat treatments can cause the cogs to become brittle and fracture in violent ways.
    63xc is a good resource for sure
    This cog had a nice long life I guess, many miles and a few chain drops over the course of 6 years. Oh well, new cog will come shortly.
    French for "Suck"
    Reputation: Aeroplane's Avatar
    Congrats on being one of the few and the proud to have broken an EAI cog. Glad you (and the bike) are okay.
