fetish SS progress...- Mtbr.com
Results 1 to 13 of 13
    get down!
    Reputation: cjh_mtb's Avatar
    A couple hours and a couple beers later, i've built the front end and brakes on my new bike. This is my first time building a bike myself... Fetish cycles Fixation frame, manitou black fork, azonic wf handlebars, easton stem and FSA pig headset. It came out right the first time, spins perfectly. Just finishing setting up the hayes hmx-1 mech's. Next step is putting together the crank. I just got the arms in today, so i'll start that in about an hour. Here's some pics
    boomer
    Reputation: okie_calvin's Avatar
    a little help please
    Do you remember what size seat post clamp that baby took? I can't seem to find that info anywhere.
    Calvin
    Wait till your wife/g-friend sees what you did to her good sheets.
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    Quote Originally Posted by okie_calvin
    27.2mm
    Expert of the Internet.
    BECAUSE I SAID SO
    Aug 2005
    I'm building up a fetish myself, I know it takes a 27.2 seatpost, but what about the clamp? And what size BB spindle are you running?
    surly inbred
    Reputation: TroutBum's Avatar
    Quote Originally Posted by demtbiker
    .. but what about the clamp? And what size BB spindle are you running?
    30mm clamp will work & a 73 x 113 bb (least that's what I ran on mine)
    Misfit Psycles
    Mar 2005
    the seat tube is slightly oversized. 31.8*1.6*2.2
    i use a 31.8 clamp...like this Seat Clamp
    the bb shell was 68, so a 73 will require a space (this is common) and the 113mm is fine.
    BECAUSE I SAID SO
    surly inbred
    Quote Originally Posted by nogearshere
    the bb shell was 68.
    My bad, this is correct. I must have been thinking of my latest build.
    Reputation: marinxc's Avatar
    80mm fork on fixation frame
    I know the frame is built around a 100mm fork but i have an 80mm hanging around that i want to use on it. has anyone used an 80mm on their Fixation SS and how did it work?
    thanks
    E !
    E ! is offline
    Reputation: E !'s Avatar
    Jan 2005
    Your work shop
    Looks similar to mine. Here i thought i was the only one using a sheet as a work pad.
    No Brakes
    Reputation: No Brakes's Avatar
    Looks good!
    I'm in the same boat as you...well...not quite. Got all the parts together but just don't have the dang time to put it together. ABSOLUTELY hate 4th quarter work!!!
    But there is something to look forward to:
    Frame: Fixation 17"
    Fork: 03 Marz MX Pro (105mm)
    Wheels: Cheapy Deore hubs w/Rhyno Lite Rims...spare set but hey, it works
    Brake Levers: Avid FR1 (OE stuff from Jenson)
    Front Brake: Avid BB7
    Front Tire: WTB Mutano's 2.4"
    Rear Brake: Avid Single Digit SL (did not want to hassle with taking off/loosening the disc caliper JUST to change a tube..f that...plus SL's got that bling factor )
    Rear Tire: WTB Weirwolf 2.35"
    Headset: Cane Creek S3
    Stem: old RaceFace (100mm x 10 deg)
    Handle bar: Easton EA50 26"
    Seatpost: Thomson (27.2 x 367mm)...will be sharing this with the NRS
    Seat: good 'ol Performance Team Forte (Ti rails, light and comfy too...will be sharing this with the NRS too)
    Seat post clamp: generic QR 31.8
    Cranks: old set of Shimano's...was a triple but stripped it and slapped a 32T x 104 ring on it (no ramps and no pins)
    BB: Shimano square tapered
    Pedal: don't know yet...flats or SPDs
    Rear cog: Gusset SS conversion kit...and since my fat a*s being doing nothing but pull 10+ hrs workdays for the last couple of months, I'm gonna put that 18T puppy on...hell, i might just have to put a 20T on that mofo!
    Like I said, the goods are in but just don't have the time. Pix to follow when the build begins...whenever that may be.
    No Brakes
    boomer
    a little mo help please
    found it, nevermind
    Calvin
    Retrograde Customs
    Reputation: dansjustchillin's Avatar
    i know i've been lagging like crazy getting new pictures up but here's some specs in the meantime.
    Frame: Fixation 17"
    Fork: surly instigator
    Wheels: red paul hubs on red mavic 517s with black DT champion sopkes and alloy nipples
    Brake Levers: paul
    Brakes: avid sd-ti
    Tires: WTB Mutano's 2.4"
    Headset: Chris King
    Stem: Ritchey pro 100mm with ti bolts
    Handle bar: Easton monkeylite xc
    Seatpost: easton ct-2
    Seat: selle italia flite
    Cranks: Race face next LPs with 34t kooka ring and SRP chainring bolts, crank bolts and dust caps
    BB: race face taperlock ti 107mm
    Pedal: ritchey comp clips or K2 flats
    Rear cog: shimano 18t freewheel
    spur chain tensioners and red kmc chain.
    Retrograde Customs
  1. Newbie needs help with SS setup
    By Little Willy in forum Singlespeed
    Last Post: 02-07-2005, 10:05 AM
  2. Newbie needs help with SS setup
    Last Post: 02-05-2005, 07:02 PM
  3. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
  4. ss fun at the tourne
    By mergs in forum New York - New Jersey
    Last Post: 11-29-2004, 09:58 PM
  5. to SS or not? that is the question
    By Nimai in forum Singlespeed
    Last Post: 04-28-2004, 11:46 AM
