eno hub vs SS Specific frame- Mtbr.com
Results 1 to 14 of 14
    I want to build a higher end SS. Am I better off using whatever connections I have to get the best & lightest frame I can, and going with an eno hub (and the hanger on there of course), or I am better served getting a SS specific Ti frame? I'm not really clear if the eno is an end all be all solution, or a good solution for those looking to make a conversion.
    Reputation: ernesto_from_Wisconsin's Avatar
    it is...
    Quote Originally Posted by gsteinb
    The ENO is "a good solution for those looking to make a conversion"
    And for me, I am clear ii is an end all be all solution. I use them, I like them, and I can practically see any hardtail, road bike, crosser, etc, as a single speed. Give ENO a try, if you have questions, PM-me here in mtbr.
    Big Drops
    If on a titanium budget, I would favor a frame with an ebb or horizontal drops over the eno hub. Personally, I found the continued slight slippage of the eccentric hub and loss of chain tension to be irritating and not too trustworthy. Of course, if there is a viable solution to preventing the adjustment from slipping - other than filing away the drops or torquing the bolts to the point of stripping the threads - the hub wouldn't be a bad option. It's a great looking piece of hardware, lightweight, and the price is reasonable when compared to other high end hubs.
    Huck Maestro
    Reputation: Tuna's Avatar
    Sep 2004
    Sounds familiar...
    I had the same debate about six months ago. I chose to go with the SS specific Ti frame with standard BB shell and horizontal drops. I am using V-brakes, but if you are going to use discs or might in the future think about the EBB with vert drops.
    Sep 2004
    Sounds familiar...
    Reputation: Solo, with others's Avatar
    Question... prob for Ernesto...
    Would it be better to have the eccentric portion of th hub below the axel in order to keep the tension on the top of the chain from pulling on it and potentially slacking the chain?
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    I went ENO. I couldnt justify/afford a ti SS frame. You can find a used ti frame for such a good deal, get an ENO with the ENO freewheel, and you are good to go.
    If you can afford a new frame, then dont go ENO.
    Only boring people get bored.
    Have you...
    Quote Originally Posted by Solo, with others
    Have you done it where you let the weight of the frame tension the ENO for you?
    I'll have to do a website for you guys so you can see how I set up my ENO, kinda like when I made the one on how to take it apart.
    Reputation: disco's Avatar
    where to get an ENO wheel built?
    where's the best place to get one of things set up? Webcyclery? for $240 with MAvic 717's seems like the way to go......but the pricetag - ouch!
    TRAIL KUBUKI CORNDOGGER
    Reputation: TwistedCrank's Avatar
    I've run an ENO eccentric hub with horizontal drops (1x1) for a couple of months and had no slippage or loss of chain tension. YMMV
    Nobody cares what kind of bike you ride.
    zeebot
    Reputation: Spookykinkajou's Avatar
    I've put 600 miles now on my ENO rear SS bike(road) and have never even had to touch it once. I have never had any slippage. I'm totally sold on the ENO and would definitely just get a regular geared frame or even a SS specific vertical drop frame but made for ENO. I like it that much. It's much simpler than the EBB and doesn't mess with your saddle position or require the regular cleaning. The ENO freewheel is very nice and a must have if you go with the eno hub.
    Like Ernesto said, you just stick it in the dropouts and let the weight of the bike tension the frame. Tighten the non-drive side some, tighten the drive side some, finish tightening the non-drive and then lock down the drive side. I didn't use a ton of torque and have had zero issues.
    zeebot
    Quote Originally Posted by disco
    I used Mike Garcia at oddsandendos.com. My roadie ENO setup with eno hub + dt swiss 1.1r, double buttle spokes and brass nipples including shipping to my door that was OVERNIGHT was about 200 dollars. Mike is awesome. give him a call. i've had all my wheels done by him and all have been perfect.
    No Justice = No Peace
    Reputation: Lutarious's Avatar
    Feb 2005
    Symetrical wheels are easy
    I built my own wheels. On a flip flop hub, the spokes are all equal length, so it was pretty easy. Read up on the web abd give it a go. You can get your local LBS to true it and get the tension right after a ride or two, if neccessary,......
    "Welcome to my underground lair...."
    Want to vent?
    Reputation: The SS Boz's Avatar
    Eno!!!
    Yep big props to the ENO hub....I think if i had the cash at the time...ECC BB Ti frame ...hell yeah...but i went with building my own ENO wheel and using my old geared Ti frame....absolutely no slippage....and i used to crank those tensioners out all the time
    BTW, got hub and spokes from Webcyclery
    -Boz
    "I'm supa-fly TNT, I'm tha guns of the navarone!"
  1. Replies: 23
    Last Post: 05-13-2010, 07:08 AM
  2. Bought a frame with a crack
    By MegaVolt in forum General Discussion
    Last Post: 06-18-2009, 11:51 AM
  3. What did my 88 Fat Chance sell for new?
    By mojo in forum Vintage, Retro, Classic
    Last Post: 06-20-2005, 02:26 PM
  4. Do I have to just live with this?
    By SoloWithOthers in forum Singlespeed
    Last Post: 04-27-2005, 09:11 PM
  5. comparison of ProPedal, Float and ALPS on same frame
    By ccm in forum Shocks and Suspension
    Last Post: 06-15-2004, 08:37 AM
