ENO eccentric hub questions- Mtbr.com
Results 1 to 2 of 2
    I have a few questions about the ENO eccentric hub. If there's an FAQ please let me know where I can find it, but in the meantime:
    What are the axle bolts like and what size are they?
    What stops the eccentric drop-out adaptors from rotating on the axle? Why don't they twist relative to each other? Is there some sort of machined flat on the axle which the drop-out adaptor bolts onto?
    Thanks,
    Alex
    I just found Ernesto's pages using the search function and therein is all that I needed to know. Thanks,
    Alex
    ps if you wanted to know why I wanted all this info, it's because I've been fooling around trying to build my own eccentric hub using the DMR Revolver as the project donor. I've got a working prototype, but there are a few refinements I wanted to make.
    Starting to appreciate just how well engineered the ENO really is. The secret is not just in the axle spacers at all.
  1. 24h rim with 32h hub? Leave every 4th hole out?
    By Duckman in forum Wheels and Tires
    Last Post: 03-10-2004, 09:53 PM
  2. White INd eccentric hub
    By jessica in forum Singlespeed
    Last Post: 02-25-2004, 09:57 PM
  3. Eccentric BB's and SS conversion questions.
    By seely in forum Singlespeed
    Last Post: 02-25-2004, 06:39 PM
  4. ENO hub is Built!
    By ~martini~ in forum Singlespeed
    Last Post: 02-24-2004, 05:43 PM
  5. ENO hub????
    By noslogan in forum Singlespeed
    Last Post: 02-23-2004, 11:10 PM
