Results 1 to 3 of 3
    Apr 2005
    EBB's, how difficult are they to retrofit....
    are EBB's designed only for EBB specific framesets, or can any bike be fitted with an eccentric, could i drop one into my old early '90s Fila Taos frameset and not need to run a tensioner, or do you need an eccentric rear hub as well?
    Brian, there's a message in my Alpha-Bits, it says "OOOOOOOO"
    Peter, those are Cheerios
    Gears, we don't need no steenking gears!
    "Mr. Britannica"
    Reputation: roadiegonebad's Avatar
    Quote Originally Posted by MacTech
    YES. If your frame is not already set up with an EBB you'll need to ginsu the BB shell and fit with an EBB shell and EBB (and repaint)... it can be done and there are folks that do it but it's major work compared to just getting a wheel built with ENO ecc hub. If you've got the ENO ecc hub you need nothing else.
    Reputation: PinsNeedles's Avatar
    I agree on the ENO hub
    Quote Originally Posted by roadiegonebad
    If your frame was an old custom Fat or something I would say get a retrofit ebb, but for the money an ENO wheel you could use on any frame and sounds like a better investment.
    Vulture cycles does ebb retrofits, I saw Wade do a Cove handjob conversion but I don't know how much it cost. This would get you a custom Derrick paintjob while you were at it though...
    ' Bend's dirtiest Acupuncturist '
    bendoregonsinglespeeders
    teamwebcyclery
  1. Shopping for a 29er is difficult!
    By Dave. in forum 29er Bikes
    Last Post: 04-03-2005, 06:34 PM
  2. '05 Switchblade coil retrofit?
    By Titus Maximus in forum Titus
    Last Post: 11-15-2004, 11:59 AM
  3. is it difficult to change stems?
    By dslfoolish in forum Beginner's Corner
    Last Post: 09-27-2004, 08:15 AM
  4. 03 XT Hydro set up (Easy?) (Difficult?)
    By Dirtman in forum Brake Time
    Last Post: 08-20-2004, 07:02 AM
  5. how difficult is it to change a bikes color?
    By madhatter07 in forum General Discussion
    Last Post: 05-17-2004, 05:33 AM
