EBBs- Mtbr.com
Results 1 to 6 of 6
Thread: EBBs
    newbie boobie.
    Reputation: donkekus's Avatar
    Oct 2002
    EBBs
    What is out there?
    What is the best?
    What is the most lightweight?
    Need to buy one.
    THANKS.
    It ain't easy being human.
    Whiskey Tango Foxtrot
    Reputation: eSSq's Avatar
    You know they don't fit in "standard" BB shells, right?
    newbie boobie.
    Oct 2002
    of course. i'm having a bike built for me with an ebb sized shell... jeez.
    giddy up!
    Reputation: donkey's Avatar
    pinch bolt?
    set screw?
    expanding wedge type?
    These are the questions you want to ask the builder, as that will determine which EBB you will need.
    Quote Originally Posted by donkekus
    www.thepathbikeshop.com
    newbie boobie.
    Oct 2002
    Quote Originally Posted by donkey
    pinch bolt?
    set screw?
    Damn... some options.
    that;s why i'm here.
    What's the "BEST"?
    Guess I'll leave it to the builder....?
    giddy up!
    Hmmm...
    I would ask the builder what they are planning on using. The expanding type uses a plane shell, the set screw type has two set screws on the shell, and the pinch bolt type has two pinch bolts on the shell.
    Who's building the frame? I could probably tell you what they normally use if it's a well known builder.
    I prefer the expanding bushnell type.
  1. EBB's
    By Manicmtbr in forum Singlespeed
    Last Post: 04-29-2004, 08:33 AM
  2. Don't forget to check your EBB's!
    By aosty in forum Singlespeed
    Last Post: 04-15-2004, 07:32 PM
