Results 1 to 18 of 18
    May 2005
    EBB vs. ENO eccentric?
    I'm looking at building up my first SS. The frame I'm interested in has vertical drop outs and comes w/wo an EBB. Seems to me the ENO eccentric hub has big advantages over an EBB (frame weight, easy access for adjustment, maintenance, etc.) but wtf do I know, I don't have any experience with either one...So I thought I'd ask the experts. Any feedback would be greatly appreciated, thanks.
    Reputation: shiggy's Avatar
    Dec 1998
    Converting gearie frame = ENO eccentric
    SS specific frame w/vert dropouts = EBB or sliding dropouts
    ESPECIALLY if you are running disc brakes.
    The ENO hub works great and is a jewel of a bike part but you still have to adjust the chain tension every time you remove the wheel.
    With an EBB it is set and forget unless you change gearing or the chain wears.
    mtbtires.com
    Combat Wombat
    Reputation: BrianU's Avatar
    Agree.
    Quote Originally Posted by shiggy
    I run a SS with the ENO hub and while it is a great way to convert a geared bike to SS, it sure would not be a practical choice for a SS specific frame. The first time you have to fix a flat out on the trail, between having to carry a 19mm wrench to adjust chain tension and all the other reasons that Shiggy mentioned, I do not know why anyone would not run a EBB. For me, the extra weight would be worth the headaches it eliminates.
    Brian
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by JSpitler
    not sure which frame it is you are referring to but as another person building up their first real SS, I was interested in getting an EBB but only a good one. My understanding is that there are definitely differences in quality/weight/etc. which of course makes sense to me. As such, I opted for a frame that came with a Phil Wood EBB which gives me the piece of mind of having the EBB but having one that will be less prone to creaking and other potential issues related to EBBs.
    my 2 cents.
    cheers
    Reputation: PinsNeedles's Avatar
    Another advantage of an EBB
    Is the ability to change your BB position front/back or up/down. My pinch bolt style ebb has 8mm of adjustment.
    I am much happier with the ebb over the horizontal dropouts on my first SS. It makes rear wheel removals much easier.
    ' Bend's dirtiest Acupuncturist '
    bendoregonsinglespeeders
    teamwebcyclery
    Dec 1998
    Quote Originally Posted by PinsNeedles
    Even easier if you remember to carry your wrench!
    mtbtires.com
    WAWE
    Quote Originally Posted by BrianU
    Eh? I just carry a hex wrench and can easily turn the eccentric axle end by hand... no wrench needed.
    Dec 1998
    Quote Originally Posted by aosty
    I think he means for adjusting the ENO, not the EBB.
    mtbtires.com
    WAWE
    I was also talking about adjusting an ENO.
    May 2005
    Thanks for response. I'm looking at the Ventana el toro, same frame as the el chiquillo. I rode my buddy's toro and fell in love with it and SS'ing. Not sure what brand of ebb but I'm pretty sure it's front/back adjustment.
    Reputation: ernesto_from_Wisconsin's Avatar
    My $0.04
    Before I depart for my ride to the office on my fixie ENOized Guerciotti, let me just say that you can choose the best option for you. ENO or EBB.
    With ENO, you can rotate the axle with your fingers enough to get the tension you need, or you can also experiment with rations to get it tight the 1st time. With ENO, you don't need to remove crank arms to adjust it.
    Also, ENO comes in disc option with an equally eccentric disc brake caliper.
    Ok, gotta ride 17 fixed miles.
    Reputation: Farmer's Avatar
    I have owned quite a few SS and now own three with EBBs. I would reccommend the EBB over the rest. It makes life much easier when it comes to maintenence as the other posters have already commented on. I have never had any noises or problems with any of my EBB frames, steel or aluminum. I also never had to take a crank arm off to adjust any of them. Also, the El Toro is an awesome single speed. I love mine!
    Reputation: RobW's Avatar
    Quote Originally Posted by ernesto_from_Wisconsin
    Huh? You don't have to remove cranks to adjust an EBB either.
    Reputation: bikeny's Avatar
    I don't know about the other styles, but I do not have to remove the cranks to adjust chain tension on my Hunter with pinch-bolt stlye EBB. I have been VERY happy with the EBB so far, and would never buy another SS frame without one, especially since I have fallen in love with discs as well!
    Mark
    Thanks Shiggy
    Next race I'll bring two tubes and a wrench to get that rear hub off...
    I didn't plan on running a marathon in the mud carrying and pushing my 25lb. bike...
    teamwebcyclery
    Dec 1998
    And I will remember to keep my pedals tight.
    BTW you are the bikemecca cover boy.
    mtbtires.com
    Yeah Shiggy,
    I should be a model,
    Tall, thin, good looking and DUMB
    teamwebcyclery
    Dec 1998
    Before the flats:
    mtbtires.com
  1. ENO Disc Eccentric project finished - pictures
    By ernesto_from_Wisconsin in forum Singlespeed
    Last Post: 03-20-2005, 01:50 PM
  2. ENO eccentric build
    By Travis Bickle in forum Where are the Best Deals?
    Last Post: 10-22-2004, 11:05 PM
  3. For ENO eccentric hub users
    By Birdman in forum Singlespeed
    Last Post: 07-01-2004, 06:00 AM
  4. ENO eccentric and bike trailer?
    By Higbee in forum Singlespeed
    Last Post: 05-21-2004, 11:24 AM
  5. ENO eccentric hub questions
    By AlexB in forum Singlespeed
    Last Post: 03-12-2004, 03:41 AM
