EBB positioning question- Mtbr.com
    Nat
    Nat is offline
    Reputation: Nat's Avatar
    When I tighten down and set the EBB, in what position should the bottom bracket be? Foreward? Aft? Up? Down? Anywhere I prefer?
    Reputation: Brandon's Avatar
    Quote Originally Posted by Nat
    Yes.
    It's a bike, if you like it a particular way then fantastic, if not... change it.
    Reputation: shiggy's Avatar
    Dec 1998
    Where ever you prefer.
    If you want more pedal clearance, run it up.
    Forward or back is going to depend more on your gearing. You might have enough adjustment to shorten or lengthen the chain to choose.
    Remember to check your saddle position after you get your basic EBB position.
    mtbtires.com
    Nat
    Nat is offline
    Quote Originally Posted by shiggy
    Just as I thought. Thanks guys!
  1. Steel EBB Question
    By AteMrYeats in forum Singlespeed
    Last Post: 01-20-2005, 12:50 AM
  2. EBB help...
    By DSR in forum Singlespeed
    Last Post: 12-20-2004, 12:17 PM
  3. EBB and gears?
    Last Post: 10-16-2004, 08:27 PM
  4. EBB possibilities question??
    By nmcculloch in forum Singlespeed
    Last Post: 07-08-2004, 08:04 AM
