EBB Positioning- Mtbr.com
Results 1 to 5 of 5
Thread: EBB Positioning
    Cars Are Evil
    Reputation: Vermont29er's Avatar
    EBB Positioning
    What the ideal position for an Eccentric Bottom Bracket? Worst position? Does it really matter? I can see how the different positons would affect handling and clearance to the ground, but I'm wondering if there's something I'm not thinking about. FWIW, I have a Rig and weigh 230.
    For position, I'm referencing looking at it from the right side. So 6'Oclock would be on the bottom, 3'Oclock would be toward the front, etc.
    Reputation: shiggy's Avatar
    Dec 1998
    Where the chain adjustment is correct. Other than that up/down, forward/back is more a personal preference.
    mtbtires.com
    Reputation: pacman's Avatar
    Quote Originally Posted by Vermont29er
    The position that places the least torque on the EBB is at 3 o'clock or 9 o'clock (sine of angle yadayada) . That only matters if you have a problem with it slipping or creaking (230 lbs?). But getting close to that postion means the right gears or even a half-link.
    Out spokin'
    Dec 1999
    Nothing matters
    Figure out your perferred seat tube angle & BB height. Put 'er there, so long as you can tension your chain with it there.
    --Sparty
    disciplesofdirt.org
    Reputation: DanU's Avatar
    I place the EBB at 12-3 or 6-9. That way, if for some reason the EBB should start to slide, it will stretch the chain rather than slacken it. Hasn't happened yet though, so it's more of a hypothetical question for me.
