EBB help- Mtbr.com
Results 1 to 2 of 2
Thread: EBB help
    EBB help
    I have a 2008 felt nine solo and ond of the allen bolts in the EBB is rounded out. I put grease on them so they would not lock up but I guess it was not enough. Any ideas on how to get it out. I don't want to have to drill it out and re-tap the hole. Thanks.
    openwound
    Reputation: voodoochild's Avatar
    You could use an easy-out.
    The one I linked to happens to be sold at Sears but you should be able to find such an item at Home Depot or other hardware stores, too. To use the extractor, you will have to drill into the bolt so that you can thread in the easy-out, but you won't have to drill into the body of the ebb.
    Hope this helps...
