EBB carbon frame- Mtbr.com
Results 1 to 7 of 7
    Apr 2014
    EBB carbon frame
    Is it safe to use a EBB with a carbon frame? Bike is a 2015 Specialized Stumpjumper World Cup. PF30 with GXP cranks. 12x142 solid axle rear.
    The rear axle and dropout configuration pretty much sucks for using the DMR tensioner, I've also used a cheap spring style but it skipped under heavy power (I'm 6'4" and almost 200lbs).
    I'd love to be able to use a EBB and ditch a tensioner altogether. I'm the original owner of the bike and I won't do anything that could potentially void the warranty.
    Thanks for any input. I can post pictures of the BB area if needed.
    I like bikes
    Apr 2014
    I take it that's a no?
    I like bikes
    aluminum BB shell? if so yes! Carbon bb shell? it is a risky move.
    Reputation: joshhan's Avatar
    Mar 2011
    http://forums.mtbr.com/singlespeed/w...ic-949407.html
    I used the BB30 version on my Chinese carbon and it's been great.
    Bikes, lots'o bikes
    Apr 2014
    Quote Originally Posted by joshhan View Post
    Thanks for the link!
    I like bikes
    May 2012
    I think that it really depends on how the frame was designed. If it has a solid carbon tube for the BB shell then maybe. If it has a bunch of holes or it it only round tube where the BB presses in and nothing in between then I would say absolutely not. And not all alloy shells are strong enough either, I saw a knock off/ no name frame with an alloy shell that buckled with an ebb installed. Maybe check with the manufacturer?
    Quote Originally Posted by meltingfeather View Post
    If I told you I saw a unicorn ****ing a leprechaun trail side, you'd probably be suspicious. :D
    Apr 2014
    Quote Originally Posted by PeopleForScience View Post
    Full carbon tube. I called the shop I bought it from and they said Specialized probably wouldn't warranty the frame if it had any compression damage from a ebb. Another shop said the same thing. I'm not willing to risk it...
    I like bikes
  1. Replies: 4
    Last Post: 04-12-2015, 05:42 PM
  2. Replies: 18
    Last Post: 08-07-2014, 02:28 PM
  3. Anti-seize or Carbon Paste for Pressfit BB30 Installation on Carbon Frame
    By jminus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-11-2013, 02:42 AM
  4. Replies: 1
    Last Post: 06-10-2013, 02:04 PM
  5. Replies: 6
    Last Post: 10-12-2011, 08:50 AM
Members who have read this thread: 4
