E.13 Tensioner :) The Slacker- Mtbr.com
Results 1 to 8 of 8
    Frequent Crasher
    Reputation: SuperBad's Avatar
    I hadn't seen this on the board yet, if it has already been posted, my apologies.
    SB
    Reputation: Brandon's Avatar
    Quote Originally Posted by SuperBad
    SB
    As long as you can get it into a position where the pulleys are closer together than the diameter of the rear cog, and it doesn't hit the frame it'll work fine.
    Frequent Crasher
    Basically I thought it was kinda neat might work for some folks... Fortunately I have an EBB on my Vulture
    SB
    Klein sits on shelf now..
    Reputation: AdroitBreaker's Avatar
    It looks like plans have been cut...
    http://www.e13components.com/archives/000014.html
    I wonder if someone could fabricate one from an old rear derailleur or something...
    Quote Originally Posted by AdroitBreaker
    You probably could but it would be a lot easier to make it out of a couple pieces of aluminum stock and a pair of deraileur pulleys.
    Reputation: the Inbred's Avatar
    yeah, they dropped it. they're working on a lot of other stuff, so this is kinda taking a backseat for a while.
    someone here has tried to rig one up using a derailleur cage, but to no avail.
    I wonder if I could do it with a dremel tool
    that's all I have. I would probably need some sort of cutter to get to rough shape from the AL stock HUH?
    Reputation: ernesto_from_Wisconsin's Avatar
    amen...
    for the ENO eccentric hub.
  1. Bianchi SISS Chain Tensioner
    By sea otter in forum Singlespeed
    Last Post: 03-03-2004, 01:23 PM
  2. Chain ring suggestions for e.13 SRS chainguide
    By Gnar in forum Downhill - Freeride
    Last Post: 02-12-2004, 08:23 PM
  3. Determining if I can go sans tensioner?
    By seely in forum Singlespeed
    Last Post: 02-07-2004, 10:19 AM
  4. rennen tensioner ?
    By dirt diggler in forum Singlespeed
    Last Post: 02-04-2004, 12:18 PM
  5. 425mm chainstays and no tensioner?
    By Timber in forum Singlespeed
    Last Post: 01-31-2004, 07:31 AM
