Dual sided freewheel- Mtbr.com
Results 1 to 10 of 10
    Reputation: oldskoolboarder's Avatar
    Does anyone know of a place that sells a built, rear wheel w/ a dual sided freewheel? Right now mines an 18T but would like to have option for 16T and 14T instead. Thanks!
    Cracker-magnon
    Reputation: gpsser's Avatar
    Quote Originally Posted by oldskoolboarder
    Do you mean like a flip/flop hub that can carry a FW on both sides, that you can flop around on the trail? If that is the case, you can get a wheel built up around a Surly hub or some other that is threaded on both sides.
    Try http://www.webcyclery.com and go to Mean Todd's custom wheel builder tool.
    "Life is a [email protected]#^ing story problem, get used to it - my son.
    Quote Originally Posted by gpsser
    Yes, like a flip/flop but w/ FW on both sides. I'd like Surly, but I'm trying to go cheap on this one...
    Reputation: shiggy's Avatar
    Dec 1998
    You are going to need a BMX flipflop hub to be able to use a 14t FW. FWs smaller than 16t use small diameter threads and "metric" FWs. http://aebike.com/site/page.cfm?PageID=30&Category=72
    You would then need to put in a longer axle.
    mtbtires.com
    Quote Originally Posted by shiggy©®™
    Good info. That'll kill my 14T idea. I'll stick to 16T/18T.
    Candlestick Maker
    Reputation: baker's Avatar
    I'm not sure how much cheaper you can expect...$102-124 for a built singlespeed rear
    wheel is pretty darn cheap.
    http://aebike.com/site/page.cfm?PageID=30&Category=1614
    I can't think of any cheaper options...
    baker
    Reputation: qtip's Avatar
    not only that...
    but if you go with a BMX hub, chainline would be a mess if you want to flip and flop that 120 mm spaced BMX hub respaced to 135.
    Quote Originally Posted by baker
    baker
    Thanks. Good to know what my options are.
    Manual4ever
    Reputation: Prime8's Avatar
    DMR Revolver
    This hub accepts a mtb freewheel and a BMX freewheel....not sure if you can get a built wheel from them, but the hub is sweet
    Look into the..
    look into a woodman/novatech/planet x singlespeed cassette hub. You can run both a 14 and 16 tooth cogs at the same time, the barrel is long enough to ft both cogs, a spacer, and the lock ring. I had a old dura ace 9sp ( 3 largest cogs) on mine and it worked.
    VernDog
  1. need your final advice on xtr dual control......
    By marco in forum Weight Weenies
    Last Post: 09-05-2005, 08:21 PM
  2. Freewheel Help Needed
    By lanpope in forum Singlespeed
    Last Post: 05-09-2004, 06:32 PM
  3. hey white industries freewheel owners...
    By head in forum Singlespeed
    Last Post: 04-14-2004, 02:15 PM
  4. 6 speed freewheel replacement questions...
    By Schmoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2004, 12:57 AM
  5. should I use my old freewheel hub?
    By jbmoocow in forum Singlespeed
    Last Post: 02-18-2004, 07:47 AM
