DT Swiss Steel Freehub Body?- Mtbr.com
Results 1 to 9 of 9
    Jan 2013
    I've been looking at a set of Roval Control Carbon wheels for my SS and the hub on them is based on a DT Swiss 240.
    Does anyone know if it's possible to get a steel freehub body for the DT Swiss hub as I find that the steel bodies last better on my current Hope hubs?
    Jan 2009
    They used to make one, but sadly have since discontinued them. Now your best bet is to try and find one on ebay.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Which part of the Al freehub fails? Because if it's the cog digging in, a wide base should fix the issue. Slight wear will probably still occur, but nothing drastic.
    Jan 2013
    The main problem is the cog digging in. I've found it to be a problem even with a wide base cog.
    I'll maybe have a look an see if there's a different cog available with a wider base.
    Reputation: Mr. 68 Hundred's Avatar
    Do you have a steel cog currently? My steel King cog bit in to my Hope steel freehub. I now use aluminum Endless cogs though Absolute Black has a cog that is even wider.
    Proponent for an Evidence Driven Life.
    Occupation: Disposable gene transfer machine
    Current HTFU status: 4/10; increasing
    Aug 2010
    Been running Surly cogs on Hope steel freehub bodies for 4 years. Freehub bodies look like they just came out of the box.
    Giant Reign Advanced 1
    Reputation: ka81ua's Avatar
    Oct 2014
    Is that the correct STEEL freehub for DT Swiss 350?
    https://www.bike-components.de/en/DT...eed-o69400118/
    HWRABX00S6530S
    OK
    I have been running a niner cog on my roval and giant wheelsets. Both are based on the 240 hub. My SRAM 10 speed cassettes cause and issue, but I have an no issues with the niner cog
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    DT is making their steel Shimano freehub again. I think a modern wide based cog is a better long-term solution, but if you need steel, they can again be had from DT.
  1. Has anybody heard of a steel Hadley freehub body with 52 poe?
    By csermonet in forum Wheels and Tires
    Last Post: 02-24-2014, 08:33 PM
  2. Replies: 4
    Last Post: 08-08-2013, 12:41 AM
  3. Steel freehub body for Stan's ZTR hubs?
    By rth009 in forum Wheels and Tires
    Last Post: 04-23-2013, 07:42 AM
  4. DT Swiss 350 / 340 freehub body question.
    By Luke_2010 in forum Wheels and Tires
    Last Post: 10-04-2011, 02:36 PM
  5. Steel freehub body for DT340
    By urmb in forum Wheels and Tires
    Last Post: 05-08-2011, 07:53 PM
