Dropout/Skewer height safety issue?- Mtbr.com
Results 1 to 13 of 13
    JAZ
    JAZ is offline
    Apr 2005
    I recently swapped a set of 520 spd pedals for a 1997 Kona Cinder Cone frame & some drivetrain parts, built it up this morning with spares I had lying around
    Set it up with 32/16 & it's so close to the magic ratio but with the axle fully in the dropout the chain is super tight (crank wont spin more than a quarter of a revolution) so I've dropped it down a bit & it's perfect now.
    Is this a stupid idea that will fail when I least want it too? Should I file the axle a bit? Or the dropout? Or should I just run it?
    I tried with an extra 2 links in & a DMR tensioner but that's too much slack to take up, got out a BMX chain & a half link but that still needed the tensioner. Plus it was BMX chain off cuts & it ran like crap so I took it off.
    Pics below on photobucket.
    Reputation: pacman's Avatar
    Just run it. With each ride the chain will wear and the axle will fit further into the dropout. Less than 100 miles and the axle will be snug.
    edit:
    make it 50 miles.
    A chain's not going to wear that fast, and I'd be worried about having the axle pull from the dropouts. I'd suggest doing it right, adding the correct half link to a 3/32" chain, and running a tensioner.
    Out spokin'
    Dec 1999
    Quote Originally Posted by bad mechanic
    ^^^ this. If it ain't right, it's wrong.
    --Sparty
    disciplesofdirt.org
    Come see me after class
    Dec 2005
    try the half link and a 15T cog. on my Karakoram i had the same exact problem. I dropped a link, added a half link, and went down 1 tooth on the cog, and it fit perfect.
    are those spokes spray painted?
    Exactly how much does it have to wear in order to fit?
    JAZ
    JAZ is offline
    Apr 2005
    Thanks everyone, I was eager to just go & ride it this afternoon, so I did!
    Anyway it held up ok over a short trail I rode, the build had a few teething issues so I cut it short (perished brake pads/bead stretched rear tyre), the skewer in the drop outs didn't move though even though I landed a few little drop off's as badly as I could without crashing.
    Was hoping to spend nothing on this bike tbh so does anyone have any reason why I shouldn't just file the hub axle down a bit? I reckon I only need a few mm to get it to fit a lot better.
    Or file the drop out a couple of mm as well, again are these silly ideas that will cause problems or still not give me enough room?
    The rear wheel is only a very cheap Shimano FH-RM30 sticker'd hub & Rigida Zac2000 rim so I don't care if it messes it up, I just like it's silent free hub. I shall consider following Alex's advice & see if a 15t/half link solves it but only as a last resort as I really don't want to run a tensioner as they ruin the look of SS bikes imo.
    Nope, they are stock black, just cheap & a bit dirty.
    Got it in a bit more after that ride, much less of a big gap now>
    Quote Originally Posted by JAZ
    Nope, go right ahead.
    conjoinicorned
    Reputation: ferday's Avatar
    by all means, DO file the axle ends flat where it sits in the dropout. this is a pretty common mod, there will be plenty of pics on mtbr and elsewhere...kinda like a poor mans ENO. you can also file the dropouts...make sure you file them slightly backwards and not straight up!
    what would rainbow unicorn do?
    Dec 2005
    my half link/15T recommendation was so you could run the axle all the way in the dropout with NO tensioner.
    JAZ
    JAZ is offline
    Apr 2005
    Quote Originally Posted by alexrex20
    Gotcha, thanks! That's certainly good to know I have that option as well
    Think I'll try the 'no expense' file option first though, so thanks to BM & Ferday for confirming that for me.
    Wear it in. As you said the gap is closing and it's closing fast. One more ride and it's good. File it and you'll eventually have a slack chain.
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    you might bend the dropout , i have
    "If women don't find handsome , they should at least find you handy."-Red Green
