Double Hex SS Chainring Bolts- Mtbr.com
Results 1 to 5 of 5
    Ahhh the pain....
    Reputation: Raybum's Avatar
    Looking for some steel double hex SS Chainring Bolts for a XT crank (not with the little slot on the back that strips). Anyone know of a source? having trouble locating one. thx....
    Stateline Falls, Watauga
    Reputation: JeffL's Avatar
    Jan 2009
    FSA makes alloy bolts that are hex on one side and T-30 torx on the other.
    I know you said steel, but I have a working theory about alloy bolts being a good safety valve in a singlespeed drive train. I've sheared alloy bolts before when a large stick, etc got jammed between the chain and ring or cog. I was thankful the bolts sheared - if they had been steel the chain or something more expensive (freehub?) might have been damaged first. I carry alloy bolts are in the spares kit in my Camelback...
    It never gets easier, you just go faster. -Greg LeMond
    I'm not as fast as I think I am. -JeffL
    Reputation: jetboy23's Avatar
    Look for Truvativ chainring bolts. They are double hex. Like here Truvativ Steel Chainring Bolts at BikeTiresDirect
    Raybum, you ever find some shorter SS chainring bolts with 2 sided hex or torx ?
    Reputation: stevland's Avatar
    no reason to run anything but the SRAMs
